New motor NO power
New motor NO power
Alright so I'm getting closer to finding my problem. I put in a new 22re with new TPS, Fuel filter, EGR delete (yes ALL vac lines are correct) so the problem I'm having the truck has no low end power and I'm not saying it's going slower than normal, I'm talking with my foot on the floor it wont go anywhere. If I get it going on a Flat it runs good in the top end but only when its cold. Today I hooked up my timing light and while it's cold timing is correct but when the truck hits 100+ degrees the timing goes retard by quite a bit, and ideas?
There is a built in system on these referred to as the "warm up" protocol it consists of advanced timing and additional fuel. Which could explain why you have discrepancy if you set the timing while cold, or while cranking which is fine to get it running, but doesn't follow the protocol.
Now if we assume it is all set "by the book", and the sensors are sending accurate, aswell the computer is receiving these signals as sent.. It maybe detecting a signal on the knock sensor.. Fuel pump, fuel lines, filter, injectors..
Before I went through all that I'd start with making sure I was following the instructions. Then proceed with making sure the sensors are clean. Follow this up with checking the voltage and resistance at the ECU.
Valve adjustment, idle, and timing are all specified to be set on a warmed up engine. So he may be on to something there.
You need the knock sensor hooked up.
The engine computer adjusts the timing for optimal engine performance. It does this partly by using the knock sensor to make sure the ignition timing is not too far advanced and causes engine knock (which will ruin your engine).
When the knock sensor is not hooked up, the computer goes into a self-preservation mode and limits the spark advancement, and that reduces the power quite a bit.
[QUOTE=old87yota;52419158]You need the knock sensor hooked up.
well done... good info
well done... good info Thread
toyospearo
Apr 16, 2011 02:29 PM
ar design
3.4 Swaps
14
May 10, 2009 11:03 AM
poolhalljunkie74
Apr 13, 2009 04:07 PM
