87 turbo 4runner speedometer
You presumably have a geared sensor, rather than a cable right? Short of re-gearing the sensor at the tail-housing... I doubt it. This site has some stock tiny gears for sale...
https://khkgears2.net/catalog5/
I would give Marlin Crawler or LC Engineering a call, those guys have seen it all. They may know of a way. I'm sure by now someone has cracked open an ECM on these trucks.
Some here have used this device to re-calibrate their electric (non-cable) speedometers when changing tire size, no idea if it would work with a digital speedo?
https://www.summitracing.com/parts/dak-sgi-5e/overview/
It might be possible to alter the digital dash, but the odometer is still going to be off since it uses a speedometer cable from transmission to dash.
You have to switch the gear on the cable at a minimum.
Speedometer isn't off five miles per hour, it's off X% unless it says five sitting still. A bit of a peeve of mine but I digress..
You are allowed somewhere between five and ten percent in the DOT regulations iirc.
SpecializedBrder
16
Oct 17, 2002 07:25 PM
