87 Pickup hood latch
Old Mar 31, 2018 | 11:05 AM
Tam McPartland's Avatar
Help! I can't access my engine compartment. The hood latch cable broke under the hood and I can't figure out how to open the hood. ?????
Old Mar 31, 2018 | 03:19 PM
Montana's Avatar
I've had this happen to me. I was able to unbolt the latch from its location in the cab and get need nose pliers where it snapped off and pull on it. Maybe you weren't so lucky and it snapped somewhere in the engine bay. I'd start with the latch inside the cab and see what you can do there.
Old Apr 1, 2018 | 01:41 PM
Couldn't do anything in the cab. "Solved" the problem by cutting away segments of the plastic grille and removing the latch system mounting bracket (3 10mm bolts). Then it was easy to open the hood. Found the cable worn & frayed but intact. It had fallen out of the bracket. I reattached the cable to the bracket with tie wire. Jury-rig will work until I get a new cable. I don't mind the damage to grille as having the sections removed makes access to the hood latch system easy if I need it in the future.
Old Apr 2, 2018 | 08:21 AM
jakey poo's Avatar
Doesn't it also make it easy for anyone else to get in too though?
Old Apr 2, 2018 | 08:56 AM
I'm not concerned about that. I don't live in a high-crime area.
Old Apr 2, 2018 | 09:28 AM
jakey poo's Avatar
yodapickup92
Feb 1, 2008 07:21 PM
wooza_b@yahoo.com
Nov 14, 2006 06:52 PM
TACORICAN
Oct 20, 2005 01:59 PM
wittekl
Aug 9, 2005 08:28 AM
CLin9383
Jul 10, 2002 04:13 PM
