Fuel injector ohms
Fuel injector ohms
who can tell me what the Ohm would be for 1995 toyota pickup fuel injectors ? Mine read 13 ohms, if that is low what would be the resin for that ? Just getting old and worn out ?
The spec is 13.4-14.2 ohms for both the 4 & 6 cylinder engines. I would say that yes, yours are just getting old. I would have them flow tested and matched. Or just replaced all together. But 13 isn't that far off they're probably just dirty.
Ok thanks, I will check the cost of new onces , and see if I can clean the others they have one whole , any input on a good brand or info on 3 or 4 wholes ,I have read some info on here but not what is good or bad, Thanks again 91 blue runner
I got my 3rd gen injectors with adapters on eBay from a seller named injectordyne (not an endorsement, just who I happened to buy from). That was about a year ago and I haven't had any issues. Had a noticeable increase in throttle response after installation, I'm still very happy with that purchase.
I checked the ohms again last night on my fuel injectors and they read at 16 ohms on some of the Utube sites some are saying any where between 14 - 17 should be good I still can't find anything on line, I don't understand why with the tech, you just can ask the qwestion and get the ans or a table that lists the in of, My Haynes manuel doesn't even say anything. Or what voltage they fire at are there any wed sites that are free that can help ?
Per Haynes Manual Page 4-2, 89 and on is 13.4-14.2
What I went thru on my injectors. https://www.yotatech.com/forums/f199...l#post51897320
Are they firing? https://www.yotatech.com/forums/f116...t-22re-270857/
Thanks Terrys87 and wyoming9 , I went back to the Haynes and looked where you said and there it was , I must of just looked at it to fast and missed it, so if the coil is open I will not get the reading of 13.4 - 14.2 ohms , I'm going to flush the injectors will that help ? I'm just trying to see if they are good and just buy some rebuild kits, I'm on limited funds.
To test them, I take a syringe, battery, hose, and some leads https://www.yotatech.com/forums/f116...jector-295953/ this is a test that will tell you if the injectors are working. Use a 9 volt battery.
FS[PacNorWest]: 1988 Toyota Pickup 4x4 Long Travel - Seattle, WA - $6500
96taco4x4
Feb 6, 2020 05:16 PM
nuknuk
Dec 11, 2016 08:13 AM
