91 4Runner transmission fluid change
Old Apr 25, 2016 | 03:49 PM
MikeM91's Avatar
Hey guys I'm new to the Toyota 4Runner but definitely not new to Toyota (I have had an MK3 supra for quite a while)
Anyways, I have a question, I bought a 91 4runner 3VZE with what I believe is the R150F manual transmission and I am unsure what fluids I can use to change the trans fluid out. I am aware of MT90 (a pain to get without ordering) but all other 75w-90 states that they are GL-5 which is too slippery. What have you guys used and is there an alternative to the Redline MT90? I am ordering some soon but if there is something that I can find locally ai will use it to hold me over.
Thanks in advance!
Old Apr 25, 2016 | 04:00 PM
MudHippy's Avatar
GL-5's fine. Won't hurt a thing.
Old Apr 25, 2016 | 04:02 PM
MikeM91's Avatar
Awesome, I was worried that it would cause problems shifting. If the bottles states that it has Limited Slip additive is it still safe to use?
Old Apr 25, 2016 | 04:11 PM
MudHippy's Avatar
That's fine. In my experience with GL-4 the difference is barely noticeable. And generally speaking not worth the extra cost. I used to think so. But I've all but given up on the notion. Then again I've never used the redline "magic sauce". Probably never will either. Since it's DEFINITELY not required.
Old Apr 25, 2016 | 04:53 PM
MikeM91's Avatar
Do you know what type of gasket is on the drain and fill plug?
Old Apr 25, 2016 | 05:26 PM
MudHippy's Avatar
None.
Old Apr 25, 2016 | 05:28 PM
millball's Avatar
Seems like my plugs have an aluminum gasket.
They should be reusable.
I am able to get Euro-spec GL-4 from a wholesale oil products place for less than $70 for a 5 gallon pail.
Old Apr 25, 2016 | 05:56 PM
MudHippy's Avatar
Turns out I'm wrong on the no gasket. Change that to a none required. I've got 3 R150Fs and 2 VF1As. None have gaskets on the fill or drain plugs. None leak a drop without them. I've seen the aluminum gasket. For whatever reason the rear diff on my 90 still has one on the fill plug(only one I've ever seen on a fill plug). And every diff drain plug I've ever seen has one.
Old May 2, 2016 | 08:56 AM
MikeM91's Avatar
Went to start my truck this morning and when I let off the clutch the truck stalled while in nuetral, any ideas?
Old May 2, 2016 | 11:25 PM
Fastbug's Avatar
My Factory service manual suggests 75W 90.
88MemphisBlues
Jul 16, 2016 01:13 PM
FinallyOffRoad
Feb 13, 2016 10:54 AM
Mhkabler95
Feb 12, 2016 10:06 PM
captainslow
Feb 8, 2016 09:11 PM
captainslow
Feb 8, 2016 09:10 PM
