Headlight Brights don't work with switch - advice?
Hi all -
I have a 94 SR5 4runner and am having the following issue:
Headlights work in low beam, but when I switch to brights, the headlights shut off.
Now, interestingly, if I use the hi-beam "flash" mode (pulling the handle toward me) the brights indeed DO come on. They just wont stay on when I switch it to stay.
Anyone have any clues?
Thanks!
Thanks!
Bad High-Beam contacts of your headlight dimmer-combo switch.
After you fix this, I suggest you do the H4 conversion harness, to fix the retarded stock wiring that leads to death of dimmer-combo switch contacts.
Thank you - I found this link as a starting point: http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
- Wires are thin (AWG 18/20?)
- Ground circuit goes from bulbs, to cabin, to dash to dimmer switch, back to engine compartment to ground inside passenger-side fender (exactly a convoluted path as 4Crawler describes it), causing a lot of resistance, a lot of voltage drops and reducing voltage that actually reaches the bulbs.
- Dimmer (combo) stalk switch contacts carry high current (10 Amps on 60-watt high beam, 17 Amps on 100-watt high beams). This will shorten contact life.
H4 Harness retrofit will fix this.
On Stock circuit:
I knew of the circuit issues, just had never heard of "the H4 conversion" before.
Was this issue ever fixed in the newer models??
If so what year or does it still continue in the 2015 models ??
I have yet to have any problems on any of the fleet.
I guess to many other maintenance items need attention .
To many projects not enough hands
I have yet to have any problems on any of the fleet. New fleet or old Yotas
You can find the wiring harness kit on eBay for around $25, and the H4 kit for about $85. There's a thread about this at https://www.yotatech.com/forums/f131...w-pics-235789/ You will lose the high beam indicator with the new harness. The headlamp difference is like night and day, well worth the money.
If you're comfortable with a little rewiring and wanna minimize cost, you can try my method. Only required ONE relay and some wire.
I rewired this way.
Basically, stock control circuit is used to control relay. Relay contacts took the place of dimmer switch contacts.
I rewired this way.
Did you ever wire up the HBI lamp?
Not yet. Havent had the chance to dig into wiring to modify. Stock config is also retarded. Uses LB to shunt across HBI lamp to keep it off, meaning current thru LB lamp still flows thru the LB switch contacts. I may just connect a current-limiting resistor from that positive side of HBI section to load side of stock headlights relay (as high a resistance as possible that wud still light up the HBI).
Here is how I fix mine without replacing the combo switch https://www.yotatech.com/forums/f199...l#post51724567
bigblue82
10
Jul 6, 2015 08:27 AM
aciorba23
Jun 29, 2015 04:18 PM
