JDM 5VZ engine help!!!
Old Nov 23, 2014 | 06:17 PM
traxxi2003's Avatar
Need some help with JDM engines; while shopping for a new JDM motor for my 4Runner I found one but I'm a little confuse with the location of the oil filter and the shape of the oil pan. My truck (97 4Runner SR5 2WD) the oil filter is towards the front of the engine, right bella the alternator. The oil pan deepest portion of the oil pan Is also towards the font. On the new motor however the oil filter is located right below the starter and the deepest part of the oil pan is also closer to the transmission. Why is this? Can this engine be installed on my truck? The seller claims is compatible with my truck. Thanks!!
PS. New a new motor because the on the old one a rod cms thru the side of the block.
Old Nov 23, 2014 | 08:06 PM
dntsdad's Avatar
Just swap the oil pan
Old Nov 23, 2014 | 11:46 PM
Terrys87's Avatar
I am not familiar with the 5vz, but the reason a lot of motors are different between the 2 wheel and 4 wheel is the pans need to clear the front axle. Usually you just need to change pans and the oil pick up assembly from one motor to the next. Not sure about the oil filter that you mentioned.
Old Nov 24, 2014 | 04:06 AM
ThorInc's Avatar
I have a 97 SR5 3,4L 5 speed 4 wd and my engine is exactly like the one you describe, oil pan deeper at back butting up against the transmission and oil filter is below the starter. Maybe get the serial # for the replacement motor and see if Toyota can shed so insight. My 4runner was at the end of that model year and I believe was made in June or July 1997.
Old Nov 24, 2014 | 04:08 AM
wii_tarded's Avatar
Pics? Could be that the new engine just might be out of an Avalon (don't know what they come with) or other FWD vehicle. Did the seller spec the engine for you VIN?
Old Nov 24, 2014 | 07:58 AM
turbo8's Avatar
My oil filter is below the alternator on mine.
Old Nov 24, 2014 | 08:02 AM
dntsdad's Avatar
I missed the part about the filter. That doesn't sound correct. I've never seen a 3.4 runner motor with oil filter as you describe.
Post pics
Something doesn't sound right
Old Nov 24, 2014 | 08:06 AM
vital22re's Avatar
totally a bro
5vz should have the oil filter on the alternator side opposite of the starter. I wonder if you even have a 5vz.
Old Nov 24, 2014 | 08:07 AM
ThorInc's Avatar
Duhh, sorry guys, CORRECTION!!!! Oil filter is just below alternator and slightly back.
Old Nov 24, 2014 | 09:08 AM
TheDurk's Avatar
Which just confirms my post in your other thread is correct:
Originally Posted by TheDurk
The 5VZ has two identical ports which can be used for oil cooler or oil filter. Put your oil cooler where the filter on your new one is and there should be a blind cover plate you can remove so you can install the oil filter in it's usual place for a 4Runner.
Just to be clear, if no oil cooler is installed, the oil filter can be installed in either of the two locations, and then the other one is blocked off. On a 4Runner, putting it in the rear would change it from a PIA to nearly impossible to get to, aside from the fact the oil cooler needs to go there.
This also means you probably need a new water pump with the cooler connection, unless your old one is relatively new, since I gather the JDM does not have one. You can sell it on e-Bay.
Old Nov 25, 2014 | 01:58 AM
traxxi2003's Avatar
Thanks everyone for your replies, like "TheDurk " stated, they are interchangeable, if your application does have an oil cooler, it needs to go in the back port. now, since my truck is a 1997, and the JDM engine I'm getting is a 2000, Will I have any issues with the engine harness and fuel injection harness?
Old Jul 24, 2019 | 01:09 PM
Tyler85's Avatar
5vz JDM engine
I recently got a JDM 5vz for my 97 Toyota 4Runner the oil filter on the new engine however is located in the back by the transmission and there's a cap on the other location.on my old engine there's an oil cooler and a oil filter do I need to swap out the oil cooler and put it on the new engine as well.
Old Mar 20, 2021 | 07:30 PM
Yobroe's Avatar
Here's what I'm dealing with: I bought a JDM engine. I changed the locations of the oil filter and oil cooler locations. BUT, on my American model engine, there is a coolant output on the engine block that feeds into the oil cooler. On the JDM engine, there is a plug installed in the engine block (tried to get it out with an impact driver - there's no way that thing is coming out). Since I've already installed a new water pump with the coolant output (that has a hose running to the oil cooler) I'm wondering if I should somehow figure out an alternate route to run the hoses...or maybe just install the cap style oil cooler that came with the JDM engine. I'm not in a high temperature environment and wonder if the cap style works in other places, why wouldn't it work where I live? Here's the other issue - the hole where the plug is in the JDM block is smaller than the hold in the american block, so if I was to remove the nipple from the american engine, it wouldn't screw into the JDM block anyway. Is cooling the oil really that important?
What are your thoughts?
Thank you in advance for your advice.
Old Mar 21, 2021 | 06:43 AM
Malcolm99's Avatar
You wouldn't think Toyota would have different block porting or threads for different 5ZV-FE's, but they where assembled and installed at different plants for many different vehicles, maybe its a Hiace thing. I would get the plug out with oxy heat and drill tap for NPT and add a barbed nipple, flush and fill.
95YOT
Jun 10, 2015 02:26 PM
rocksockdoc
Feb 15, 2013 07:44 AM
The Ruckus
14
Oct 18, 2010 09:50 AM
TC4RNR
Jan 8, 2008 07:27 PM
Asha'man
Jun 15, 2006 09:37 PM
