Anyone know where to find replacement weatherstriping?
The weatherstrip above both doors on my 91 pickup ext cab 4x4 are garbage and water is leaking in pretty bad. I've been searching everywhere and can only find seals for the door jam. The piece im looking for is just along the top edge of the door where the drip channel runs. Wouldnt mind buying a whole kit of replacement seals but I can't seem to find that either.
Anyone know where I can get these other than ebay for $100 each?
Or anyone have some they are willing to part with?
any help greatly appreciated!
http://toyotapartsoverstock.com/
They carry the weatherstrips you need but, not much cheaper than EBay.
Thanks! I was able to find it on another site, but then looked at toyota overstock as well and it was a few $$ cheaper.
Not to mention a quick search for a coupon code (thankyou5) gave me another 5% off!
The hard part was figure out what they called the stupid piece, which turned out to be the weatherstrip for Door Side Rail, on some cars its call a drip channel others door rail.
Thanks for the help!
Weatherstrip Roof Side Rail RH 6238189101
Weatherstrip Roof Side Rail LH 6238289101
These are the part numbers for the JAPAN imported models ONLY! for some reason the US manufactured models are different and cost more...
Install and removal is simple enough,
pull out the old weatherstrip
maybe clean the lip of the roof rail so you have a clean surface to work with (and repair any rust while your at it)
Then apply some adhesive to the new weatherstrip and push it onto the lip.
It's not rocket science, should be self explanatory.
I've added some pictures to show the piece I am referring to.
The first picture shows the weatherstrip that runs just above the door seal
The second and third pictures so both ends of it starting about where the side mirrors are and ending in the upper rear corner of the door. As you can see its pretty easy to just pull off, might just be that mine is so rotten that it seems easier though.
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
