95 4runner 3vze Belt Alignment Problems
Old May 6, 2014 | 06:41 PM
StayFoolish22's Avatar
So i just replaced the timing belt, water pump, fan bracket for my girlfriends truck. That all went swimmingly.
Reason I replaced was as we were driving down the road the whole fan assembly blew out and forward, truck died out. So I had to replace that bracket, look inside, belt is shredded.
So after the replacement, which went great, truck was running fine for 3 days.
Today the alternator belt pops off because the power steering belt is pushing it out. Now it looks as if the fan and the pulleys attached are pulling themselves forward towards the radiator again. There is about a half inch of room where it seems like it should be more aligned.
Basically I don't know what to do, or why it is happening. I am at a loss.
Alternator belt is falling off due to power steering belt rubbing against it. It looks like the power steering belt is rubbing because it is being pulled out at a weird angle.
Will try to post pictures, we are in the middle of nowhere on bad satellite internet.
Thanks everyone, ask questions if I was not descriptive enough, kind of burnt out from the day.
Old May 7, 2014 | 02:30 AM
Cyberman's Avatar
Need to see the pics.
Old May 7, 2014 | 07:56 AM
Tried
Tried taking some car porn pics, hard as a self made producer.
So yeah, I don't know why but it seems like the fan is pulling out. The picture shows the deflection from the PSP. Tried also taking a top down but yeah. Will attempt clearer pictures soon.
Attached Thumbnails 95 4runner 3vze Belt Alignment Problems-cam00036.jpg   95 4runner 3vze Belt Alignment Problems-cam00035.jpg
Old May 7, 2014 | 08:13 AM
Better Shots
Got some better pictures now, you see if i was to tension the alternator again it would just pop the belt right off once i start it up. No clue why it is happening.
The bracket that holds the fan assembly is new, bought for 278$ at napa. The old one exploded out. I also replaced the timing belt and water pump. Again the truck ran fine the last 3 days, no squealing no problems. And to the best of my knowledge the belts lined up initially.
Attached Thumbnails 95 4runner 3vze Belt Alignment Problems-cam00037.jpg   95 4runner 3vze Belt Alignment Problems-cam00039.jpg
Old May 7, 2014 | 10:27 AM
Found the issue
So why would the fan assembly bracket be getting pulled out. This would be the 2nd time it is happening. The power steering pump and the alternator are aligned perfectly with the crank, so I don't know how it could be getting pulled out.
Any tips or thoughts. I am at a loss.
Old May 7, 2014 | 10:42 AM
Cyberman's Avatar
That bracket is either not installed correctly, or is the wrong one.
Was searching to make sure the belts were on right, and found this post from 2010
Old May 7, 2014 | 10:46 AM
The bracket matched up perfectly to the one that was one the truck, and there is really no other way to install it. I had it flush to the engine and torqued to spec. I appreciate the responses man, I really do.
Old May 7, 2014 | 11:28 AM
Cyberman's Avatar
Did a little more searching, and found another post from the same guy as above.
Click Here.
Maybe send MaK92-4RnR a PM, and see what his story was, and how he fixed it.
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
