Shifter Stuck in Park
Old Feb 12, 2014 | 11:59 AM
break88's Avatar
Hello everyone, I just bought a 1990 4 runner v6 sr5 4x4. To operate the shifter I have to use the shift override button. I have searched on the forum and what I found was to replace the brake fuse. I did this but it still doesn't work. Any other ideas?
Thanks in advance.
Old Feb 12, 2014 | 12:43 PM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b...55shiftloc.pdf
Note that a "brake" fuse is not in the circuit; I assume you mean "Stop."
As with any electrical problem, you'll need a multimeter. No, there is no other way, not even to save $6. http://www.harborfreight.com/7-funct...ter-98025.html
Old Feb 12, 2014 | 02:24 PM
YotaWoRx's Avatar
It's the shift lock computer. It's a small black box to the left of the shift lever with 3 plugs I believe. U have to take off the plastic trim around the lever to see it. It's in a bad spot. It gets super hot where it's at!
Old Feb 13, 2014 | 04:39 PM
superex87's Avatar
In order for the shift interlock to disengage it needs to see a brake signal. Check to make sure the brake light switch ( down on the brake pedal) is plugged in and working, also check to see if your brake lights light up when stepping on the brake pedal.
Old Feb 15, 2014 | 03:08 PM
break88's Avatar
Checked the "stop" fuse and it's good. Also replaced the brake switch. This piece under the trim is the last thing to check.
Kreedy1
Sep 8, 2015 06:33 PM
eggens
Sep 5, 2015 12:16 AM
AkitaDog
Sep 3, 2015 09:01 PM
Motomonty
Aug 9, 2015 05:53 PM
Tonetrk
Aug 3, 2015 08:47 PM
