Questions on Cornfed Spacers
I received some Cornfed spacers today and wanted to make sure on two things.
1. The inner ring on the bottom of the spacer is a different height on each one - 3/8" on one, 5/8" on the other. But since this portion sits inside the coil, its not a big deal right?
2. I had wanted spacers to provide 1.5" lift, and no more than that. I was then expecting the top part of the spacers to be about 3/4" tall. The ones I received are 1" tall. Will these give me 2" of lift?
Originally Posted by TDiddy
Problem solved. You don't use the stock top plate with the studs in it any longer, that accounts for the 1/4" difference.
Originally Posted by humanoid
I'm expecting the same spcers in the next few days. Can you take a pic for me so I can see how the installation looks close up? I just bought replacement shock mounts for my new shocks as well and wondered if I needed to return them or something.
do you want a finish shot of what the strut/coil looks like after the spacer is installed? on the truck? we did a spacer install on saturday. we have another today. and another on friday so i can try to get some pics done.
should give you 1.5 with that, I think that mine (1.5) were the same height couldn't accuratly measure because I'm using them to compensate for the sag on OMEs due to winch and bumper
"The inner ring on the bottom of the spacer is a different height on each one - 3/8" on one, 5/8" on the other"
----don't recall the difference
Hey Tom-
Are you gonna use these with your OME coils, or your old stock ones? Which OME coils? Just wondering...I have 881's that sagged, so I added a 1" CB and it gave me back my lost lift, but it is pretty stiff sometimes, they really only compress about half way to the bumbstops...I'm thinking about taking them off and just putting in some sort of top-out spacer instead.
The other thing to note, which you may already be saavy too, is that the OME shock dust cover will not fit inside the CB spacer. You do have a few choices, though, you can go without, get some bilstein dustcover (the blue ones like Schaefer has in his Frankenstien write-up) or you could pick up some soft rubber shock boots in the color of your choice. I got black ones from Summit Racing, made by superlift...Good Luck!
Originally Posted by beachtaco
replacement shock mounts??? or are you talking about the shock bushings? what do they look like?
Still waiting for those spacers. It's been about 2 weeks since my check cleared and David still hasn't delivered them yet, maybe I should give him a call. Thanks for all your help!
Well, here's a pic of what I was talking about. It's the thing on the left. Any and all pics that you can take would be fantastic.
cornfed is on vacation at the moment. i think he will be back next week. i'm not sure about his shipping status though.
Sep 4, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
