Pre 84 Trucks 1st gen pickups
Newbie here! Weber carburetor questions.
Old Jul 6, 2013 | 07:18 PM
itjlee's Avatar
Just purchased a 1982 toyota pickup, it is the first carburated vehicle I have ever owned and im looking to expand my knowledge on the 22r and some carb info. Ive spoken with a few of my local old school mechanics and im looking at about $150 for a rebuild on stock carb, but I was told its easier and a better choice to spend the extra $75 and get a weber.
I am stumped on which carb to get so im looking for some insight from a yota pro
http://www.webercarbsdirect.com/Toyo...etors_s/41.htm
On webers website they list 3 differnt carbs for my truck, how do I know which one is a direct replacement for my stock carb? Any help would be greatly appreciated fellas! Thanks.
Old Jul 6, 2013 | 07:51 PM
gennro's Avatar
Weber 32/36
Old Jul 6, 2013 | 08:35 PM
itjlee's Avatar
Thanks, should I purchase through Weber directly or is there any sites out with a better deal?
Old Jul 7, 2013 | 05:03 AM
81 Toyo's Avatar
You'll need to decide between electric choke or manual choke on the 32/36 Weber.....
Old Jul 7, 2013 | 10:59 AM
catfish21's Avatar
Weber carbs direct sold me fake weber I went through lc engineering
Old Jul 7, 2013 | 12:41 PM
itjlee's Avatar
Thanks for the reply.
I'm guessing this is the correct kit
http://www.lceperformance.com/Weber-...-p/1030021.htm
And when I purchase this kit will I need anything else to make the install complete?
Old Jul 7, 2013 | 12:57 PM
catfish21's Avatar
That will be everything you need but the adapter plate that comes with the weber likes to leak so I got the pro spiral adapter that the also sell and I love it no more vacuum leaks and they claim it gives you a few horsepower to good luck
Old Jul 9, 2013 | 01:48 PM
itjlee's Avatar
Thanks for the help catfish, I plan on slapping a weber on in a few weeks and maybe she'll run a little better.
Old Aug 11, 2013 | 09:21 AM
Logan1985yota's Avatar
Is the manual choke a cable that you can route from the carb to the inside of the cab to pull by Hand when starting the engine?
Old Aug 11, 2013 | 09:23 AM
catfish21's Avatar
Yes it is
Old Aug 11, 2013 | 09:28 AM
Thank you Catfish21. I am looking into buying a 32/36 for my truck because of choke problems on the stock carb. Witch style choke did you put on your truck and how is it working for you?
Old Aug 11, 2013 | 10:08 AM
catfish21's Avatar
Dgev electric choke and I love it
Old Sep 7, 2013 | 04:45 PM
Dans1stoy1982's Avatar
so I have a 1982 fwd pickup and just got a 32/36 weber from weber direct manual choke. Is it a fake? My pickup has a automatic choke on it now, if I use the manual choke what do I do with the wires from the electric choke?
Old Sep 9, 2013 | 12:06 AM
JonnyBoy's Avatar
Dan, those connections can just be capped off. If you've gone with a manual choke and don't need electric, they're useless.
Everyone else, I've never seen a fake 32/36, all the fakes I've seen so far have been the 34/34's. just saying, the 32/36 I bought off my buddy and put on my '83 was a real Weber and the jets and synchronous kit fit just fine, never a problem(other than the cast spacers that came with the kit that someone else mentioned. I went with the LCE spiral adapter as well, and it's a great investment cause the Webers run like crap when there's vacuum leaks) He bought it from webercarbsdirect.com.
Old Sep 9, 2013 | 06:52 AM
Bingle's Avatar
Johnny Boy,
That is mostly true, there are China knock offs out there and a Solex (sp?) built 34/34 is NOT the Spain built Weber 32/36 that people are ordering so you're not recieving what you thought you were paying for.
Old Sep 9, 2013 | 08:14 AM
Sweet Thanks, the carb that webercardsdirect sent has a stamp that says 32/36dgev172 on it so its ok then I think. So on the adapter kit im looking for the lce spiral something or rather? The ones I got is part kit number 100.746.
Old Sep 9, 2013 | 10:32 AM
Bingle's Avatar
This:
http://www.lceperformance.com/Spiral...-p/1033028.htm
Or this would be the way to go if you had not gotten the carb already. Has everything you need to do it right, including the FPR and the right adaptor:
http://www.lceperformance.com/Weber-...-p/1030026.htm
Old Sep 9, 2013 | 11:02 AM
I've go the carb already and I am not in any hurry so I'll just order it from LCE.
Thanks for the help
JonG85
Jan 18, 2023 04:31 PM
kawazx636
Oct 6, 2021 03:03 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
93RedKrawler
Sep 29, 2015 02:50 PM
