'94 Landcruiser power window problem....
The passenger side rear window has apparently "slipped" out of the frame/track. It will power up if you pull up on it, but slides back down (open). What do I need to know to get the door panel off without destroying it and/or the clips? And what and how should I lube the mechanism when I get that far? Thanks in advance! psulkosky@aol.com
There is a discussion going on right now on www.ih8mud.com about this same thing, when you pull the door panel off there is a plastic sheeting to keep water out of the electronics that you basically have to ruin and replace to fix your window head over to that site for more info, Brad.
Jun 1, 2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
