Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
'94 Landcruiser power window problem....
Old Feb 14, 2004 | 01:49 AM
EXFFPM's Avatar
The passenger side rear window has apparently "slipped" out of the frame/track. It will power up if you pull up on it, but slides back down (open). What do I need to know to get the door panel off without destroying it and/or the clips? And what and how should I lube the mechanism when I get that far? Thanks in advance! psulkosky@aol.com
Old Feb 18, 2004 | 02:28 PM
Bradass80's Avatar
There is a discussion going on right now on www.ih8mud.com about this same thing, when you pull the door panel off there is a plastic sheeting to keep water out of the electronics that you basically have to ruin and replace to fix your window head over to that site for more info, Brad.
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
