curiousity, wider axles that fit 1st gen 4runner thirds?
Old Nov 23, 2012 | 01:07 PM
live4soccer7's Avatar
I'm curious, are there any wider axles that fit the 1st gen 4runners (and all the other applicable gens/models). I know there is the IFS rear axle that is 3" wider (have one), but looking for any other toyota axles that would be able to have those thirds bolt right up (or small modifications). Just curious really, just like to know options for future ideas or needs.
Old Nov 23, 2012 | 06:00 PM
dropzone's Avatar
Fossilized
t100..
Old Nov 23, 2012 | 06:20 PM
slacker's Avatar
and 2wd Tacoma , but unfortunatly wont fit
http://home.4x4wire.com/erik/diffs/#T100-Tundra
Old Nov 23, 2012 | 10:38 PM
aww.... so no other yota axle options for use with the older 8" diffs that would result in a wider width besides the ifs rear axle?
Old Nov 23, 2012 | 11:19 PM
85toy4runner's Avatar
I wonder if the 90-97 Landcruiser FJ-80 solid axles will work .
Old Nov 24, 2012 | 02:13 AM
Vang530's Avatar
I think they take bigger 3rds..like 9.5" or something?
Old Nov 24, 2012 | 05:24 AM
mightymouse's Avatar
fj80 will work. Would need to mount them with your suspension but the thirds will work. My high pinion in my front axle is from a fj80.
Old Nov 24, 2012 | 06:27 AM
MudHippy's Avatar
FJ-80 & FZJ-80 Landcruisers have 8" front and 8.9" rear axles.
These vehicles also had an optional 8.875" REAR electric locker. This one has been retrofitted into other Landcruiser models with considerable effort (see this article), but it doesn't appear to be compatible with any non-Landcruiser vehicles.
http://home.4x4wire.com/erik/diffs/#electric_lockers
Old Nov 24, 2012 | 07:27 AM
The hippy is correct
Old Nov 24, 2012 | 08:07 AM
MudHippy's Avatar
Then it occurs to me. The 1 ton full-floater dually rear axles are probably wider, and they use the same 3rd members(8").
Originally Posted by TheRevenant
...I am using the toyota full float 1-ton dually rear axle, it was sold on toyota motor homes, some models of long chassis flatbed trucks, and the toyota U-Haul trucks, I had to hunt around to find it, but they do exist.
here is a pic of the 1-ton axle compared to the stock '84 4x4 rear axle:
https://www.yotatech.com/forums/f198.../#post51992665
Old Nov 24, 2012 | 09:53 AM
What is the width of the dually full floater rear? WMS to WMS? I know the rear axle housing on an IF is 58.5" (older ones are 55").
79-85 front axle~ 55.5", rear axle~ 55"
'86-95 front IFS~ 59", rear axle~ 58.5"
Tacoma 4x4, '96-up 4runner front IFS~ ???, rear axle- 60"
T100 front IFS~ 65", rear axle~ 66.75"
Tundra front/rear~ ??
'90-97 Landcruiser FJ-80/FZJ-80 front axle~ 63.5"
Perhaps the dually rear with a 90-97 land cruiser front could made a good combination? I have an ifs rear sitting around and want to make a full floater out of it with a rear disc break conversion etc... The trucks and up getting a little tall, so the wider wheel base would be an added plus (preaching the choir, but pointing the obvious out).
Old Nov 24, 2012 | 10:32 AM
MudHippy's Avatar
One guy says:
OK So I measured. 77" outside tire to tire, and 52.5" backplate to backplate.
Another guy says:
6 bolt rear dual wheels,new cooper 185r14 8-ply tires.76.5 inches.
This guy says:
it is 61.5 inches WMS to WMS (wheel mount surface to wheel mount surface)
From these threads:
http://toyotamotorhome.org/forums/in...showtopic=1819
http://toyotamotorhome.org/forums/in...showtopic=2610
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
TNRunner88
Jul 1, 2015 08:00 PM
