My 88 keeps killing fuel pumps!?!?
Old Jun 24, 2011 | 03:10 PM
VANCE164's Avatar
Ok so I cannot for the life of me figure this out in the last 3 months my 88 with a 22re has killed 3 fuel pumps. Does anyone have any ideas of why this would be happening you put one in it runs great then after about a month it just goes I've put in 2 napa one and one new Toyota pump.
Old Jun 25, 2011 | 01:01 AM
wyoming9's Avatar
Smile
Just curious are you the type that runs around with the fuel tank level around 1/8 to empty all the time.
I have a few Toyota vehicles that very seldom if ever I let the tank go much below half..
I never had any issues with pumps.
Just what kind of failures ??
If they all failed within that short period most fuel pumps are warrantied for a year.
Interesting
Old Jun 25, 2011 | 03:42 AM
The MAN's Avatar
I hope you've been replacing the filter sock too... fuel pump warranties are usually void if you don't replace the sock... also if the high pressure filter isn't replaced, it too can cause problems
Old Jun 25, 2011 | 05:15 AM
corax's Avatar
You've also replaced the fuel filter? The pump will burn up rather quickly if it has to work against a restriction like that all the time
Old Jun 25, 2011 | 06:00 AM
VANCE164's Avatar
Yea filter has been replaced two time the truck rarely goes below half a tank and the sock is replaced every time and yes their under warrenty but it becomes a PITA to drop the tank once a month and to have the truck leave you stranded
Old Jun 25, 2011 | 06:43 AM
sb5walker's Avatar
Check voltage at the pump. If low, that could cause problems. Should be close to same as at battery posts, I think.
Do you use any fuel additives?
Are you sure your fuel pumps are actually bad, and not some other problem like bad pressure regulator, circuit opening relay, fuel pump switch in air meter, or wiring?
Old Jun 28, 2011 | 10:07 PM
VANCE164's Avatar
Thanks sb I'll check into these well actually my g/fs brother bought the truck from me so I'll pass the info on I just replaced it 2 times first one lasted 8 months 2nd one died a few weeks later so then he replaced the napa one I used with a Toyota one and it died on him two weeks later so thanks everyone for the help
VANCE164's Avatar
And no fuel additives.
Old Jun 28, 2011 | 11:57 PM
vital22re's Avatar
totally a bro
is the COR bypassed? is the pump staying on all the time? any kinks in the hardlines? Is the vehicle running rich or lean? Pumps rarely go out by them selves. Something is causing them to fail. I know that clogged fuel filters are usually the biggest culprit. Pull the filter and try blowing through it in the direction it should flow. Is it easy to blow or no? When you pull the failed pumps, can you hot wire them and get them spinning by tapping on them? maybe they suck in debris? Maybe your charcoal canister is failing and sending its guts to the tank? Good luck!
Old Nov 13, 2014 | 05:58 PM
StarThrower's Avatar
I have this same problem!!
Vance! What ever happened with this vehicle? I have the same issue with my mini cooper and the last mechanic just gave up on it! Only problem is mine is actually worse! My car only lasts a day or two before killing the fuel pump and I've been through 5!! I am hoping you can shed some light!!
Old Nov 13, 2014 | 10:04 PM
RAD4Runner's Avatar
Almost all possible causes have been discussed on posts above. Read them?
Charecter1
Nov 6, 2023 10:08 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
redneck17
Jul 17, 2015 07:44 PM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
