94 truck will not crabk after timing kit replaced
94 truck will not crank after timing kit replaced
Guides broke and installed whole new kit from engnbldr. The gears are in correct and aligned right. Put on tdc and installed distributor at 12 o clock and it rotated perfect to# 1. Won't crank. We tested with timing light as we were trying and it all was in time and hitting good time. Not sure what to do now. We did not remove head or anything fuel relayed. Getting fire on all plugs. I do know that the alternator ground is not hooked up. What else do I do look to? It seems as if it is 180 out or something. Im baffled
Assume a 22RE engine?
When you say "won't crank", do you mean the starter is not running?
Or that it tries to run but can't turn the engine over?
Or is it turning over and not starting?
Hard to tell from the vague description of the problem.
make sure it looks like this----->>>> https://www.yotatech.com/forums/f116...l#post51463797
coil wire on?
plug wires correct?
check CSI as stated above?
gas in the tank? (i'm not being sarcastic....just make sure)
if you only did the front end, you should have only removed the 1 ground wire by the alternator....you already mentioned that.
EFI fuse?
plug wires correct?
EFI fuse?
ok...it will not run..it will turn over fine, but will not crank up and idle for those that are not completely unsure of what i am talking about. in the south cranking it the vehicle firing up and running...not doing anything is nothing
voiddweller
19
May 2, 2016 09:10 PM
