DT header gasket advice ?'s
Old Nov 21, 2010 | 10:25 AM
muddpigg's Avatar
So finishing a head gasket replacement. The stock style exhaust gasket is not sealing up with the DT header. Has anyone had success using hi temp sealant to fix such a problem. Going to try it anyways as the holidays are close and the santa fund is only so big, so need to conserve funds for now.
Old Nov 21, 2010 | 10:47 AM
87hillbillyoter's Avatar
never tried it but DT does supply sets of gaskets that do work. i got em on mine
Old Nov 21, 2010 | 10:50 AM
muddpigg's Avatar
Some how I seem to have lost them. I sometimes suck working out of a car port. I had to mail the head back to the builder so have had quite a bit of waiting since project started.
Old Nov 21, 2010 | 10:54 AM
i meant they have them on their site.
http://dougthorleyheaders.com/products/sfID1/8/sfID2/47
Old Nov 21, 2010 | 10:57 AM
muddpigg's Avatar
I know was looking for a cheap quick fix. Truck has been down for almost 4wks and is starting to cause household problems.
Old Nov 21, 2010 | 02:24 PM
muddpigg's Avatar
Nope this idea was a fail.
Old Nov 21, 2010 | 02:34 PM
vital22re's Avatar
totally a bro
I would see if there is an aftermarket gasket that might work better. Maybe from different manufacturer?
Old Nov 21, 2010 | 02:35 PM
muddpigg's Avatar
Was wanting to be up and running today, going through withdraws. Was thinking Remflex or just a replacement DT gasket.
Old Nov 21, 2010 | 04:32 PM
RustBucket's Avatar
I don't have experience with headers but I have used Remflex with good success in the past.
Old Nov 21, 2010 | 05:01 PM
muddpigg's Avatar
Was thinking of Remflex. Seems the issue is the 22RE head has pair shaped exhaust ports and the DT header is round. The OEM style gasket (Victor Reinz) won't seal; not the sound off leaking air but a loud ping/pop like the port is open with no exhaust. Its at the 4 cylinder at about the 10/11 oclock position. When I pulled the the gasket out to try the sealant it was obvious on the crush ring where contact was poor. Don't know if I should be looking at a 22RE pair shaped gasket or a 20R with the round shape? Thinking the round is a better choice.
Old Nov 22, 2010 | 05:33 AM
RustBucket's Avatar
The Remflex gaskets are also easy to cut with an exacto-knife. I recall that the gasket I used didn't have the correct shaped ports for some reason but it was very easy to modify using the old gasket as a template.
Old Dec 3, 2010 | 03:57 PM
muddpigg's Avatar
The Remflex has worked great was able to local source so no waiting for shipping. Thank you Billy Bob's Offroad for coming through again.
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
clok
Aug 1, 2015 09:42 PM
Iceman4193
Jul 15, 2015 04:48 PM
Coreyr384
Jul 10, 2015 11:13 AM
