Temperature gauge running too cold?
Hi guys, new here.
Just recently got a '94 Pickup (22RE), and I've noticed the temperature gauge is barely lifting 3-4 centimeters away from cold when it's completely warmed up. This seems too cold to me, but then again I know nothing about Toyota's, so I'm just making sure. My guess was that a temp. sensor is off, though.
Thanks for the input you all. Peow, I probably am meaning millimeters. What I'm trying to say is the needle is barely moving at all. Just to make sure, I'll take a picture and put it up here sometime tomorrow. I'll check the thermostat, too.
Years ago I had the jiggle valve jam into the thermostat in such a fashion that it kept it from closing. My gauge barely moved off cold. This was a stock Toyota thermostat. It made my wonder why the jiggle valve was so close to the thermostat valve.
Well according to you, Raze, I think I'm good. I've yet to drive the truck in hot weather yet, so I don't know about that, but it does stay around what you showed as your idle reading in the current weather (50's-60's).
The temperature gauge in my '91 22 RE runs 1/3rd of the way over when warmed up and driving down the highway, regardless of the outside temp. I have a thermostat the dealer put in, I believe it's a 190 degree model. I drilled a 1/16th inch hole in it to prevent the temperature from spiking when running the heater in winter.
I used to run a 180 degree thermostat, and the gauge only went about 1/4 of the way over. At the time, I thought this was better for the engine (less heat, longer life) but I have since become convinced that these engines need to run slightly hot in order to burn gasoline efficiently (better mileage) and not leave as much residue behind.
I had one of those, but I changed the sensor(only), and now it reads about a lines width under half at normal, and maybe 2/3rds up at 80mph@100º outside temp. I figure the higher reading will scare me sooner if it ever seriously overheats.
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
closer, cold, cool, gauage, gauge, long, running, runs, temperature, temprature, thermostat, theromostat, time, truck, yotatech
