lost dash lights
lost dash lights
Lost all my dash gauge lights, the fuse is fine, the clock, and radio are functioning - any place else I should be looking at? '94 runner 3.0 5sp
see if you have heater control panel lights, and that they dim up and down with the dimmer switch.
if they're out, it may be that switch. if the clock doesn't dim with lights on, it may be the headlight switch.
if they work fine, and it's just at the gauge cluster, pull the top of the cluster off and check the three plugs at the back of it. if someone has pulled that cluster out in the past, a connector may not be seated.
good luck!
good luck!
the clock light does not dim with the lights on, and I get nothing on the dimmer - no heater control lights at all. I did find a blown 15a tail light fuse, replaced it thinking it may have something to do with it. nada. Where is this headlight switch?
yeah i have a dimmer it's turned all the way up, haven't checked to see if it's became unhooked. i noticed months ago that when i went through water puddles my lights would work and then when it was really dry it wouldn't it's weird
yep get some trailer lights ground them off and tie them in with the cd player never forget to turn them off or on
like most of us the cd player is always on when we're driving and off when we cut the truck off
Pull both tail light bulbs and check the sockets for corrosion, I had a corroded socket and it was popping a fuse on me.
Also, the fuse panel itself can get broken - there's a bunch of flat circuits behind the fuse panel that are sort of easy to damage, I busted one of mine when inserting a fuse tap and had to get a new (used) fuse panel. (My dash lights were knocked out by the broken circuit.)
ashersullivan88yota
Jan 18, 2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
Johntom240
7
Jul 13, 2015 12:18 AM
