86 4runner rear window will not roll down - HELP Please
Old Jun 5, 2010 | 02:23 PM
John101477's Avatar
ok just got in the runner today after the wife has drivin it 2 times the last few days. Not saying thats the problem but here is what we have going.
neither switch works but I do hear a click from a little box on the driver side behind the panel in the back seat. any idea and worst case how do i manually role down the window if need be?
Old Jun 5, 2010 | 03:53 PM
John101477's Avatar
Ok I was able to jump it to the down position. I am running a wild guess that it has to do with the relay system they have on the driver side. unfortunatley i have no clue how to fix that even if I had the parts. Any ideas if that can be by-passed?
Old Jun 5, 2010 | 04:08 PM
Kiroshu's Avatar
Do you have the service panel off?
If so theres a white connector. Its 3 wire. the connector may be clipped up under the tail gate inside. Unplug it and jump a piece of wire in the first and thrid female terminals.
Problem fixed.
You are by-passing a "lock switch" in the tail-gate latch to the left side which goes out constantly in these trucks.
Old Jun 5, 2010 | 04:44 PM
John101477's Avatar
ok I got it figured out it ended up being a wiper issue. at least I got a chance to lube up the mechanism while I had everything off.
I found the fix on 4crawler along with a laundry list of why these things go out.
Thanks kiroshu.
Old Jun 5, 2010 | 04:47 PM
kiyobrown's Avatar
Glad you got it fixed. Wiper would have been my first suggestion.
The 4 crawler site is good for troubleshooting so many things on these rigs.
Old Jun 15, 2010 | 07:53 AM
grantc80's Avatar
John 101477, I was wondering when you regreased the gears what grease did you use. Also, what did you use as a cleaner to clean everything really good back there. My back window is very slow and make lots of noises when rolling up and down.
Old Jun 15, 2010 | 08:15 AM
John101477's Avatar
well I used some wd40 to clean it all up. as you can imagine this created a lot of crap on the window itself but i made sure to rinse with warm soapy water as well BEFORE rolling up the window. i made that mistake once already. as for grease a light white grease will do wonders. IMO your standard bearing grease will pick up to much dust but then again I need to pull off the panels to check and see how mine is after this last trail. I ran with the top off so i have not used the window in a few days.
Old Jun 15, 2010 | 09:42 AM
grantc80's Avatar
Thanks John101477 for the input. I will tear it apart and clean it up once my window parts arrive.
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
