98 tacoma wont go into 1st and 2nd sometimes
i am having a shifting problem, its hard to put in 1st and 2nd gear sometimes, but i never forced it in, its like something is blocking , is this a comment problem ? could it be the gear or the shifter , or just the bushings?
thanks guys
thanks guys
i went out and drove it some more, it seems like there is a lock , if i do over 20mph it wont let me down shift to 2nd or 1st, but as soon as the needle drops below 20mph i can put it in 2nd but not 1st, it does this everytime, seems there is like a lock or something, i have a 2.4 5speed 98
i looked there is fluid in the resivior
Don't try to downshift into first going 20 mph, that will cause your syncro to get messed up.
Take scubas advice and check those things out, also check tranny fluid level and see if the fluid looks really dirty or something.
i just took it for a ride , my neighbor has the same truck, she rolled with me , i was able to put it in 2nd , but i have to use a lil muscle, i never drove a truck before maybe this is the way it should be , she said that this truck is diff from my honda, honda shifts so much smoother. i will check on those things tomorrow thanks you guys
i appreciate all your help!
Make sure the GEAR OIL is warm before you say it just shifts rough.
To check the level of the GEAR OIL park the truck on level ground and climb underneath. On the drivers side of the trans you will see a 24MM bolt, pull that and stick your pinky in it. If you have fluid within 5MM of the top you are fine.
Change the gear oil before coming to conclusions.
Your W59 will work okay with Mobile 1 75W-90 GL5, but the w59s are kind of picky and like the GL4 you can get at the dealer..
In case you needed it, here's your trucks FSM
http://www.ncttora.com/FSM/2003/index.html
Well, its for an 03, but mostly all the mechanical junk is the same.
vanion2
Jul 29, 2015 06:17 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
