Is Your Rear Pinion Seal Leaking?
Does your gas tank look like this?
Does your rear diff look like this?
Does your rear diff look like this underneath?
Now if you are still not sure take out the rear pinion seal and compare it to a new one?
Yep, I think it was toast and needed replacing.
Took all of 30 minutes and no more leaking.
Jeez. I wish mine only took me 30 minutes. Mine was so seized in there I had to cut it out with a dremel and mini cutting wheel thing. I tried to muscle it out before. Took me nearly 3 hours to finally get it out!!
As a mater of fact mine does. It wont after I install the e-locker from a Taco I have sittin on the bench in the garage. And Wabbit we are all jealous of all the tools and nice shop that you have, at least I am anyway. by the way congrats on the shop.
if your pinion bearings are toast it will leak again i have replaced mine like three times in the last year now wile waiting to get my new thirds with 4.56 and my aussie in.just kept puttin new seals in to keep the oil down.gear oil mixed with mud is the hardest crap to get off.
plus the crappa seals suck. i can definetly see the diference in the oem seal.imo
jerusry
Oct 19, 2015 05:28 PM
mmmm snap on truck.
