weber fuel return
Old Mar 21, 2010 | 10:28 AM
RAMROD84's Avatar
weber fuel return
i'v got a weber 32/36 and im going to be putting an electric fuel pump on my truck . im wondering how do i hook up a fuel return line? do i even need a fuel return? any help would be appreciated
Old Mar 21, 2010 | 10:49 AM
xxxtreme22r's Avatar
do not hook up the return line. Weber specifically says to remove and plug it. The reason being if you ever hook a pressure regulator and gauge (which you should be using anyway) to it you will see how much fuel pressure jumps up and down with a return line. also make sure you get a fuel pump designed to dead head and provide 1-4psi. Also depending on where you want to mount the fuel pump, under bed or inside engine bay, some pumps do better pushing and some do better pulling.
Old Mar 21, 2010 | 08:02 PM
RAMROD84's Avatar
I got the electric pump on and a fuel pressure regulator and everything is working great so far. Thanks for the help
kazuya2416
Apr 5, 2024 02:17 AM
okamikai
Apr 30, 2018 10:19 PM
gmonnie123
Jul 26, 2015 02:44 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
