Bunch o' 22ret and 3.4 stuff...Downey headers too.
Old Oct 19, 2009 | 05:48 PM
lbhsbz's Avatar
Ok, here's the final list of all my spare stuff...all the prices are off the top of head so make offers if you think I'm too high...or just high.
22RET Airflow meter: $50
22RET charge pipe from Turbo to TB $50
22RET turbo oil feed/drainback line $40
22RET injector resistor pack $30
22RET coil w/ ignitor, $40
22RET Distributor w/ newer cap/rotor/wires $50
22RET 4x4 oil pan and pickup $20
22RE/T crank pulley/balancer, new from dealer $75 (paid 160)
22RE/T balancer, no groove on seal surface $40
22RE/T rocker assembly. good shape, $40
22RE valve cover, $10
22RE starter, used $30
22RE starter, rebuilt, never used $75
stock SA L and R inners, $50
R151F turbo bellhousing $200
Front IFS diff w/ 4:10 gears and a trutrac $250 SOLD
Trans to engine brackets $10 each
A/C bracket w/ idler $20
A/C compressor (minus the fittings) $50
PS pump, used $25
PS pump, new ATSCO reman, $100
PS high pressure line (turbo specific) new $75
Lower turbo radiator hose w/ header hose tee, newer $40
Newer 22RE GMB waterpump, 8K miles on it. $25
2" tube OBD 1 cat, less than 1000 miles on it, $30
2.5" tube OBD 1 cat, new $50
From the 99 Tacoma prerunner doner rig
99 3.4L 4x4 A/T ECM - $100
2001 3.4 M/T 4x4 ECM - $130
Early 3.4L cast exhaust manifolds, no crossover $50
Downey 3.4L headers with crossover $350
Underhood fuse box w/ cut harness $20
interior fuse box $20
ECT switch $10
Old Oct 19, 2009 | 06:34 PM
RMA's Avatar
RMA
You got PM...
Old Oct 20, 2009 | 04:51 PM
RMA's Avatar
RMA
Payment sent , thanks !!
Old Oct 21, 2009 | 09:11 AM
Greg_Canada's Avatar
Downey crossover, is it for a 3.4 swap or stock 3.4?
Old Oct 21, 2009 | 03:39 PM
lbhsbz's Avatar
The headers were on a 99 tacoma 3.4L
Old Oct 29, 2009 | 05:47 PM
jdmmike's Avatar
pm sent
Old Nov 18, 2009 | 06:27 PM
Libratsio's Avatar
Still have the 3.4 DT headers?
Old Nov 30, 2009 | 04:30 PM
87turboyotals1's Avatar
Does the charge pipe to the tb still have the elbow onto the TB ?
Old Dec 19, 2009 | 09:52 AM
lbhsbz's Avatar
nope.
Old Jan 10, 2010 | 05:36 AM
SleevelessSteve's Avatar
Hey would you happen to have the cylinder heads themselves for sale? I'm looking for the passenger side cylinder head for a 3.4L.
Thanks
Old Mar 17, 2010 | 10:46 AM
theMonch's Avatar
Headers still available?
Hi, still have these? If so could you send picts via PM or email? Thanks.
Old Mar 19, 2010 | 08:15 PM
just call me smithy's Avatar
how much for the manual tranny?
Old Mar 19, 2010 | 08:17 PM
nevermind im dumb... what i ment was is it in good condition?
Old Mar 19, 2010 | 10:44 PM
olharleyman's Avatar
Got a pic of the 3.4 header cross over? I need one or at least an idea what it should look like if I have to build one for mine.
Old May 29, 2011 | 08:50 AM
Scavngr's Avatar
22RET turbo oil feed/drainback line $40 still avail?
Old Jul 13, 2011 | 10:23 AM
petyamiller's Avatar
PM sent
jb451
7
Oct 7, 2022 06:58 AM
FJtoyman
Sep 8, 2015 04:47 AM
Squigglez
Sep 4, 2015 07:33 AM
DiggnDeep
Sep 3, 2015 02:45 PM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
