working on t.belt w/p right now HELP
Old Aug 21, 2009 | 03:50 PM
y2kltdsport's Avatar
I just removed the toppulley between the cams and removed the t.belt and the cams each moved a little ,by themselves, one even got a nip on my finger is that normal and will it screw me up lineing up marks, any and all advice will be greatly appreciated thanks, Mike , wanna get this thing back together
Old Aug 21, 2009 | 05:03 PM
Anybody please
Old Aug 21, 2009 | 05:08 PM
peapicker's Avatar
Its normal, The tension of the rocker arms on the cam lobe is what made them move when you took the belt off. Just make sure they are back on the marks when you get it back together. If you get way out of line, just put the number one cylinder on top dead center and line the cams up on there marks and you will be good to go
Old Aug 21, 2009 | 05:23 PM
Thanks alot for the reply Peapicker, can you go into more detail for me, ie lining up the marks tdc etc. is # 1 cyl the front drivers side?? thanks again so much, felling like I got in just a lil' over my head, but can't turn back now
2000 runner
Old Aug 21, 2009 | 05:37 PM
peapicker's Avatar
Theres a couple ways to get on tdc "top dead center." Look at the crankshaft, put the keyway slot at 12 o'clock, or use the timing mark on the crank pulley, put it at tdc on the plasting cover with the timing advance scale on it. or take the plug out of the 1 cylinder "if your looking at the engine its the first one on the left" and put some type on blunt non metal object "i like using a plastic pen" in there to feel and see if that piston is up. put the pen in and rotate the crank and watch the pen. Do not let it fall past the plug hole! You will have to pull the head to get it out!
Old Aug 21, 2009 | 05:40 PM
peapicker's Avatar
If ya can pics are handy
Old Aug 21, 2009 | 05:45 PM
peapicker's Avatar
Holy crap dude I gave u some bad info! Hold on a minute!
Thanks again! when I get tdc with the crank(belt off) can (or do) I then turn the cam pulleys each clockwise till the notches line up on top with the grooves??
Old Aug 21, 2009 | 05:54 PM
peapicker's Avatar
You have a 3.4? this is how the crank should be set
Old Aug 21, 2009 | 05:59 PM
peapicker's Avatar
Yes sir, get the crank right, put the belt on it, get the right cam where it should go, work all slack out of belt and around the right side pully, then under the idler, around the left cam pully and on to the tensioner. Dont let tension off or the cams will slip a tooth or two on the belt! Happend to me 3 times before succes!
Old Aug 21, 2009 | 06:19 PM
thanks for your help again, and your patience< I believe I understand, its fine to turn the cams to their marks at the top,(clockwise yes?) then with the crank mark lined up like in your pic try to get the belt on while keeping everyone on their marks.sound right?? thanks Mike
Old Aug 21, 2009 | 06:27 PM
peapicker's Avatar
Yes clockwise is fine. Good luck dude, it can be a little aggravating! need 3 hands kinda thing. After you get every thing on and tight, turn the crank one revelution and check marks again. Just a failsafe, measure twice cut once
Old Aug 21, 2009 | 06:37 PM
have a great weekend my friend THANKS!
Old Aug 21, 2009 | 06:40 PM
peapicker's Avatar
You are quite welcome, Let us know how it turns out.
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
