Driveline vibration on 1st gen 4runner
Old Oct 9, 2003 | 09:45 AM
Duffdog's Avatar
I just bought a used 88 4runner yesterday and noticed that when decelerating in gear, there is a vibration coming from the rear end of the vehicle. anyone have experience with this? maybe a u-joint or the diff? I got a good deal on it too-- only 2000 dollars, no dents, came with 33's, slider bars and the engine runs well!
oh, one other question, the owner never put it in 4WD in about 4 years, is there some type of maintenance that needs to be done to the transfer case or the front axles?
Tim
Old Oct 9, 2003 | 12:41 PM
CTB's Avatar
CTB
Ya, bad u-joints can cause a driveline virbration, but you usually notice it all the time (not just decelerating). Also, it could be that the driveshaft needs balanced...I read about that a few times as well. Since your rig is 15 years old, replacing the u-joints wouldn't be a bad idea anyway.
Old Oct 10, 2003 | 07:58 PM
Duffdog's Avatar
thanks dude..
just for fun, i took the rearend out and had it rebuilt and put a new u joint in the driveline. the vibrations gone now-- and so is the funky whining noise from the rearend.
T
Old Oct 10, 2003 | 08:13 PM
Adam F's Avatar
Originally posted by Duffdog
tjust for fun, i took the rearend out
yea, that is loads of fun isnt it?
I'd change the front diff fluid and if you have manual hubs, take off the 8 or so 10mm bolts and look inside and see if there is still some grease in there. 4 years without 4x4, with 33's and sliders? I dont get it.
Old Oct 10, 2003 | 08:20 PM
Duffdog's Avatar
can you change the front diff fluid easily? like i wont have to disconnect any belts or brackets or stuff like that?
--o ya, the sliders really arent sliders, they are the fake-ass nerf step bars that bolt to the shackle mounts. The people that owned it before me just bought it for groceries and driving around the city, i think it was the owners before them that had the problem....
T
Old Oct 11, 2003 | 06:52 AM
I will NOT offer any help until I see some pics
Always anxious to see pics of other's 1st gens
Old Oct 14, 2003 | 07:31 AM
Erich_870's Avatar
How do you change U-joints?
I assume you pull the drive shaft off, but do you have to get a special tool? I have a bit of vibration at hwy speeds and mine is an 87' 4Runner.
Thanks
Old Oct 14, 2003 | 09:30 AM
Duffdog's Avatar
first of all- before pulling off the driveshaft, reach under there and try to shake it up and down, back and forth. if there is any movement in the driveline at the u-joints, then change them. my u joints were actually burned and expanded and there were no needle bearings left--just metal grinding on metal. the manual says to use a hydraulic press to remove the cups, but i broke my vice doing that and elected to just use a big ass hammer and a socket that matched the diameter of the cup. after an hour of hammering, the u joint just fell out.
Tim
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
