'03 Tacoma door panel removal advice
Old Oct 14, 2003 | 07:19 AM
ewarnerusa's Avatar
I don't know what's up with the search, I read that others aren't getting much from it. Even a simple search of "door" only turned up 13 matches. Anyways, does anyone have any advice for getting the front door panels off to access the speakers? I'm ugrading to Kenwood 5x7's all the way around. I successfully did the rear speakers already, if anyone needs help with that let me know. I think the front should be easy, too. but I was surprised to to not find any search results for it. Anyone have advice? Thanks.
Ed
Old Oct 14, 2003 | 08:43 AM
3.4v6's Avatar
are 5x7's the sizes of all the stock speakers (except the tweeters) on most late model tacomas?
Old Oct 14, 2003 | 08:46 AM
ewarnerusa's Avatar
According to Crutchfield, yes. I think that there was some 5 1/4" for a while, but with the 6-speaker system they are all 5x7. I used the crutchfield search and it says 5x7 all the way around. Looks like you've got a 4-door, though, so I'd do some checking first.
Old Oct 14, 2003 | 08:49 AM
ewarnerusa's Avatar
crutchfield says 6x8 (5x7) all the way around for 2003 doublecab.
Old Oct 14, 2003 | 08:59 AM
Bob_98SR5's Avatar
ewarner,
look in the tech section. hboss has a write up on that. also in my 'sound deadening' write up, i have instructions on how to do that too.
while it might not be exactly like your 03, i doubt that the removal process is any different.
bob
Old Oct 14, 2003 | 09:14 AM
3.4v6's Avatar
yea ... i read somewhere is was 6x8 for the d-cabs. just makin sure i get the right size in the future. thanks man
Old Oct 14, 2003 | 09:30 AM
ewarnerusa's Avatar
5x7 and 6x8 are the same. good luck! I must say that even with just the rears replaced and stock head unit my sound was MUCH better. I can't wait to have them all upgraded.
Old Oct 14, 2003 | 09:32 AM
ewarnerusa's Avatar
Originally posted by Bob_98SR5
ewarner,
bob
Thanks. I still didn't see anything in the yotatech writeups, but I printed out your deadening the doors section from your 4runner site incase it helps.
EDIT: found it in yotatech, too.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Cplmike
Jul 8, 2015 08:47 PM
AaronM
Jul 8, 2015 07:15 PM
ItsJustD
Jul 7, 2015 07:49 AM
