1988 Toyota 22re EFI has starting problems please help
Old Aug 3, 2009 | 11:39 AM
bhatch's Avatar
My 1988 toyota 22re will start great and run great up until it gets ran for a period of 30 min and when your turn the switch off and try to restart it just spends over. After the truck has cooled down a hour or two later it will start right back up again. I"ve replaced the coil & Ignitor and also the dist. and this has not fixed the problem any help would be appreciated.
Old Aug 3, 2009 | 12:33 PM
4runnerx3's Avatar
What brand of spark plugs do you have, and when were they changed last?
Old Aug 3, 2009 | 12:43 PM
bhatch's Avatar
NGK and changed approx. 1 month ago
Old Aug 5, 2009 | 11:54 AM
bhatch's Avatar
Thanks for your quick response 4runnerx3
Old Aug 5, 2009 | 12:00 PM
scuba's Avatar
Originally Posted by bhatch
I guess new people dont get help on this site are you guys are not as smart as you think. Thanks for your quick response 4runnerx3
New people get help.
Smartasses dont.
Alot of time people who dont search wont get alot of help.
Pretty sure issues like this have been covered before on this forum.
Old Aug 5, 2009 | 04:58 PM
bhatch's Avatar
I see your post on that dumb azz. No answer scuba so i guess you fit the category thanks for nothing if that fits you wear it.
Old Aug 5, 2009 | 05:08 PM
peow130's Avatar
Well, because you're just being rude to everyone else, they're probably NOT going to answer your questions.
Old Aug 5, 2009 | 05:54 PM
bhatch's Avatar
sorry scuba just very pissed off at this truck about right now.
Old Aug 5, 2009 | 07:51 PM
abecedarian's Avatar
Hard to start warm?
Because you've been rude, all I should say is I'd suspect something's wrong.
Since you've edited replies and apologized to at least one member:
maybe intake duct leak, vacuum leaks, faulty engine temp sensor, leaking fuel injector(s), low (or possibly high) fuel pressure, incorrect ignition timing, wiring issue or cam timing or valve adjustments... maybe even a whole series of tune-ups done that mask a faulty idle / air control valve.
Hope I didn't give you too many things to consider.
And troubleshooting info for all those is available through Yotatech's search function and through various Factory Service Manuals which also can be found with the search function.
6th Gear
19
Dec 10, 2019 07:31 AM
Crazychris1871
Jun 27, 2016 10:38 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
torgeir
Jun 25, 2015 05:26 AM
Old Red 94
Jun 16, 2015 08:32 PM
