22re timing chain quick question
how hard is it to slip the cam gear off? im thinking of just pulling the timing cover and taking a bunch of slack off of it and make sure i put it on correct. Having a hard time determining which ones are shiny links on the chain according to the FSM. My problem is that im not sure how old this timing chain is but it certainly is a pain to see anything on these chain links, only thing i can identify really is "napa" on the links so that makes me think someone did it in the last 170000 miles lol.
i had a big complicated mess with my timing when i originally bought this truck and the cam timing gear was about 3 teeth off, took it to a mechanic and he re adjusted the cam gear but apparently its still 1 tooth from where it "should" be.
At this point I wouldn't worry so much about the mark on the cam gear. These are for aligning the gears and the chain in a new installation. Since the drive gear and cam gears are at different ratios youll probably never actually see them lined back up after the initial install. Rotate your motor to TDC/Compression, 0 degrees, then look and see if the alignment spline on the cam shaft is at 12 o'clock,not 11. if it is not, then remove the Distributer, then the bolt that holds the cam gear on. better remember which way you want to move the gear before you pop it off! Best to mark it before. Move the cam shaft to the 12 o'clock position. Only move the gear in the direction that will get you to 12 o'clock.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
