3VZE LH Fender Ground
Old Jul 4, 2009 | 04:40 PM
kagrimm's Avatar
Hi,
I am replacing the 3.0 engine in my 94 4Runner. During the transfer of parts I broke off the grounding strap that connects to the drivers side fender. According to the wiring diagram it grounds the ignition noise filter (which I believe is the plug which connects to a capacitor/condensor next to the ignition on the fender), daytime running light resistor (I don't have daytime running lights and don't see a connection for them on the strap), and it connects somewhere on the block/header. My question is where on the block/header does the strap connect. I think it broke off the metal bracket which is bolted to the upper left side of the LH head between cylinder 2 & 4 but need confirmation.
Thanks,
KG
Old Jul 4, 2009 | 04:51 PM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Just went out and looked at mine. It is attached to the head above the exhaust manifold, and below the valve cover.
Old Jul 4, 2009 | 04:54 PM
kagrimm's Avatar
Thanks for your help.
Old Jul 5, 2009 | 12:11 PM
wighty's Avatar
I melted both my grounds under the hood... one that goes to the block and the one that goes to the PS fender.... I suggest using a heavier gauge ground.... im now using a 4ga. ground.... I was stuck in nowhereland Hunting... good thing the truck wouldnt start... since I shot my first bear while waiting for grounds to show up from my buddy
punks_is_4x4
May 31, 2016 06:03 AM
89fourrunner
Feb 17, 2016 06:52 AM
JHalcyonM
Sep 14, 2015 01:10 AM
gp66
Sep 7, 2015 08:29 AM
viesail
Sep 5, 2015 04:23 AM
