Domestic Swaps Chevrolet, Ford, ect
Want to put a 302 in a 91 4Runner
Old Apr 28, 2009 | 06:50 PM
Ripclaw101's Avatar
I just bought a 91 4Runner Automatic with 293k miles on the engine and tranny. I have read about the underpower issue with the 3.0 V6 3vze engine. when going up steep hills it loses a lot of power and I have to push the peddle through the floor for a while to get it to gear down and start to pick up speed again. Even sittin still then hammering the gas in gravel doesn't throw much. I'm not a mechanic, but I assume it's getting to the end of it's life and instead of dropin a lot of cash into an underpowered engine I was wondering how much would go into droppin a 302 V8 into it. Any and all info you can give me will be appreciated. Started calling around to junk yards for a good engine. Was thinkin about getting the brain box wireing harness, tranny. the works.
Thanks,
Troy
Old Apr 29, 2009 | 05:31 AM
Adam F's Avatar
It will cost you more than a basic rebuild on a 3vze.
More money, and time.
Old Apr 29, 2009 | 07:49 AM
Ripclaw101's Avatar
Thanks. Will there be a lot of fabricating involved? I am pretty sure motor mounts will have to be moved around, but beyond that I have no clue. Just kinda wonder how much work will go into it as opposed to putting a newer 3vze engine back in it. Not even sure rebuilding the old engine would solve the power issues, so not sure it's worth it.
Old Apr 29, 2009 | 07:53 AM
yodercrawler55's Avatar
THe motor mounts will have to be moved, wiring it up to the truck is gonna be a pain, should fit since the truck had a 3vze in it, I doubt there will be firewall mod. Tranny mounts will have to be customized thats pretty much it for fabricating
Old Apr 29, 2009 | 08:22 AM
Ripclaw101's Avatar
Found a lot of info in this thread. Sorry didn't see this before. Will read through here for info.
Old Apr 29, 2009 | 08:26 AM
Ripclaw101's Avatar
Thanks for the info. Gonna see how cheap I can get engine for. Looked at new ones, but think I would save a lot of cash if I find one at the junk yard that's in good condition.
Old May 28, 2009 | 01:06 AM
gjms5150's Avatar
its easy you just have to make motor mounts. I went with a painless wiring harness and everything is great. I did however go with a chevy nv4500 5 speed transmission that was tricky!
Old Jul 26, 2013 | 06:11 PM
banoobee17's Avatar
If going to a 302 carb what fuel system do you use
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
