help ID this noise/problem plz
in 4wd @ highway speeds when i let off the gas pedal i hear a rattle/vibration that sounds similar to the engine but slightly louder and it seems to be coming from around the right front tire or thereabouts. i had a peak at the CV boots and they are not torn but i know that isn't always necessary to indicate a CV problem. i didn't check the u-joints on the drive shaft yet, but that is my next theory. anything else that might be causing this sound? thanks in advance.
U-Joint was my first thought...
how many miles on them that you're aware of? when's the last time you greased them?
for $15 and maybe 30 minutes an end, if you're unsure about their condition, I'd replace them anyway; seen Yotas&Jellos's thread recently with the broken flange?
Oh, and LMAO at your sig; pig and elephant DNA just wont splice, bahahaha, that was a funny episode
Um...Brendan, check out this thread....
https://www.yotatech.com/forums/f116...lay-ok-162143/
Be sure to read the write up in the link provided. See if anything with that or the thread itself sounds familiar.
I noticed mine makes noise vibration with hubs locked with or with out 4h at highway speed. I'm going to check grease u joints and axle oil, tomorrowish and unlock the hubs since most of the roads a clear now. Possible driveshaft out of balance or damaged, too.
Thanks, this helped me.
still not sure what the cause is. i drove around to listen to it some more and it sounds kinda like an engine brake, just not nearly as loud and it only lasts for 2-3 seconds after i let off the gas pedal in 4wd
FS[PacNorWest]: Really Nice Truck on WA craigslist
Esibnitsud
Jul 21, 2015 08:51 AM
