Crankshaft Pulley
Old Nov 15, 2008 | 08:47 AM
eagleusa24's Avatar
Crankshaft Pulley
Can anyone tell me how to remove the crankshaft pulley?
I'm going to replace the seal. I think is leaking and that could mess up the alternator with all that oil being sprayed onto it.
How can I keep the pulley from moving when taking off the screw?
Old Nov 15, 2008 | 08:52 AM
TOYOTA 1's Avatar
use a breaker bar, let it come up tight on the frame rail then hit your ignition.
the motor will turn over and loosin the bolt. dont forget to pull the coil wire so the motor dont start!
Old Nov 15, 2008 | 11:54 AM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
x 2 on the braker bar and use a nice 6pt impact socket if you have it, my buddy used some junk 12pt from Wally World and stripped the bolt. The rest of the night sucked after that.
Old Nov 15, 2008 | 12:04 PM
fishon1213's Avatar
another way
X2 on the breaker bar
another way is to put a large pair of vise grips on the edge of the pulley, when the vise grips come into contact with the other pulley, it will not allow the crank to turn. Be careful not to damage your pulley.
I have used this method before in a parking lot to change an oil pump when all I had was some cheapo sockets and vise grips.
Old Nov 15, 2008 | 12:20 PM
Rocketwrencher's Avatar
Impact wrench works well if you have one.
Old Nov 15, 2008 | 12:35 PM
blackspyder's Avatar
put the truck in high gear and turn it loose using a regular 6" rachet and deepwell 19mm socket. works for manuals not sure if it'll work on an automatic.
Old Nov 16, 2008 | 09:33 PM
abecedarian's Avatar
won't work on an auto.
impact or the breaker bar / crank the engine are the easiest
Old Nov 16, 2008 | 09:45 PM
drew303's Avatar
make sure you put the cheater on the correct side of the motor. Motor turns clockwise. ... just see ya putting the breaker bar on the wrong side of the frame rail and it swinging through and destroying everything in its path =)
but I've NEVER had to use this method.
Put the truck in gear and use a cheater bar to break the bolt.
rusche's Avatar
2nded. Stripped one when I first got the truck. Pounded on a size smaller 12pt to get it off, still a giant PITA
Old Nov 18, 2008 | 06:53 AM
eagleusa24's Avatar
I will try the method you guys have recommended. Another question, does anyone know the crankshaft bolt tightenning torque specification?
I'm also thinking whether replacing the timing belt now or not since I don't have the directions to do it. I would like to replace because I'm not really sure when it was replaced. Does it need to be replaced every 60,000 miles?
Old May 26, 2010 | 03:05 PM
Ron Helmuth's Avatar
revive a thread!
good old thread-I do use search!-wish I had looked on here a month back doing this for the 89 MR2.
We fabbed up this special service tool imitation to limit the counterclockwise rotation of the crankshaft (lefty loosey-right to tighten) so we could use a jack handle 4' long to get enough leverage on the bolt.
The inner big hole is for the socket, the outer holes to screw a bolt into each side of the pulley. It worked!
Attached Thumbnails Crankshaft Pulley-0410-toyota-special-service-tools-homemade-001.jpg
Old May 26, 2010 | 04:55 PM
swampfox's Avatar
If you are leaving the radiator in, it doesn't hurt to protect it with piece plywood.
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
EVars
Sep 29, 2015 02:06 PM
voiddweller
Sep 28, 2015 11:21 PM
charlie_fong
Sep 27, 2015 10:06 PM
