Applyiong badges to vehicles
Old Oct 10, 2008 | 11:53 AM
Corey's Avatar
Co-Founder/Administrator
Awhile back I bought a badge from a local Overlanding/Expedition forum I joined for the Pacific Northwest.
It is an all vehicle forum which is Toyota, Land Rover, Jeep, Mogs, and more.
I picked up some 3M Super Strength Molding Tape at Schucks Auto Supply, I hope it is the right stuff.
Here is the badge.
I imagine I use some wax remover such as Griots Paint Prep, and then apply the tape on the back of the badge in strips to voer the whole thing, and then press firmly against the sheet metal?
I have never done this before.
I am thinking of putting it on the rear door below where it says FJ Cruiser.
Old Oct 10, 2008 | 02:25 PM
Trustyrusty's Avatar
Yup, thats the right stuff, I work in a body shop doing collision repair, and thats exactly what we use, just wipe the spot down with denatured alcahol or some prep clean, then apply the badge, and wipe off the ch micals with some water..
Old Oct 10, 2008 | 04:30 PM
Corey's Avatar
Thanks for the info.
It says to apply the tape at 65 degrees and above, it is only going to get to 58 degrees tomorrow.
Not sure if I should wait, or if that will be OK.
Old Oct 10, 2008 | 04:55 PM
DIHOWARD's Avatar
I think it would look better if you used the tabs on the sides and screw it on somewhere, maybe to the snorkel, along the fender, with silicone of course!
if your'e not going that route it would look nice if you CAREFULLY filed off the tabs.
cool badge either way!
Old Oct 10, 2008 | 05:28 PM
aviator's Avatar
You could use a heat gun or hair dryer to raise the surface temp of the spot in question. Then gently heat the area after application for a few mins. to aid the curing process.
Old Oct 10, 2008 | 05:38 PM
Corey's Avatar
To take off those tabs would require a trip to a machine shop, I do not have the tools to make it perfect.
No screw holes on my snorkel
I thought about drilling into the ARB bumper up front, not sure yet.
I could always tape it on the back still, and then use fake black screws glued over the holes or something.
Hair blower would work Paul, I still have mine I use to use thirty years ago
Old Oct 10, 2008 | 06:11 PM
Corey's Avatar
An idea...
I was just outside with the badge and I think it will look best from the rear, and not the front of the rig.
Another spot came to me, the hub cover for the wheels.
It could be screwed to the cover for the spare tire.
A poor attempt to paste it in
What do you think?
Or the original plan, to the right of the key lock on the rear door.
Old Oct 10, 2008 | 06:14 PM
algranger's Avatar
i say go next to the key lock
Old Oct 10, 2008 | 08:32 PM
aviator's Avatar
If you want to screw it down I'd go on the gray plastic under the Toyota by the lower left hinge opposite the plate. I think it looks kinda dorky on the hub... but that's just me...
Old Oct 17, 2008 | 10:27 AM
Corey's Avatar
Installed today.
I may change the location in the future.
One thing with this tape though is it does raise the item above the sheet metal more than the factory emblems.
They must use a thinner tape?
Also installed an Overland Journal sticker above the YotaTech sticker over on the left side of the window.
Old Oct 17, 2008 | 11:02 AM
aviator's Avatar
Looks good corey but you should get a couple of round top SS philips head screws cut off the shanks and super glue the heads into the holes on the badge. It will look a lot nicer.
Old Oct 17, 2008 | 11:07 AM
Belize Off Road Team's Avatar
I just use double sided tape. it has held my hood ornament on through the roughest roads, the thickest mud and the most insane monsoon season yet.
Old Oct 17, 2008 | 11:31 AM
Corey's Avatar
Thanks Paul, I was thinking about doing that later.
All out of Super Glue, will have to get more.
The stuff I used was double sided too, just thicker than I would like.
Old Oct 17, 2008 | 11:54 AM
aviator's Avatar
Thin is good... the tighter they are to the body the less room there is for water and dirt to get behind and the harder it is for vandals to pry them off on you.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
mojo4x420
Sep 16, 2015 08:07 AM
matt1833
Sep 16, 2015 07:11 AM
