99 4Runner V6 smoking on startup?
I just went to start it and it was smoking a whole bunch... I looked under the hood and I checked the oil, that was fine but then I saw the coolant reservoir was empty. It wasn't empty a few days ago when I replaced the timing belt, water pump, etc.. I did notice that the thermostat had a slight leak around it. Nothing serious just a few drops but I can't imagine that leaking out the whole entire reservoir. That also doesn't explain my smoking problem... The only thing that I can muster up is that it has a blown head gasket. It only smoked on start up not while driving. Any ideas?
The smoke is white... I just went to start it up and there was absolutely no smoke and the reservoir was as full as it was when I filled it up this morning after I noticed the smoking issue. The engine was not warm when I just started it, it had not been started for about 9 hours. BTW when I started it the first time it was about 70 degrees outside and now it is about 80 if that makes any difference.
Yea I'm pretty sure it's the HG... Can I drive it like this for a while? I drove it about 50 miles today and it didn't leak at all. I really can't afford to replace the head gasket this soon but I am willing to spend $10 a month on antifreeze.
dzldust
7
Oct 6, 2015 05:39 AM
joeynational
Sep 5, 2015 01:54 PM
