Power Window Question
Old Apr 25, 2008 | 08:17 AM
jar73186's Avatar
I recently purchased an 84 4 runner. The PO said that the windows were dead and would have to be replaced. After getting the FSM for an '85 I figured out the little breaker in the kick panel by the fuses. My problem is now I can roll my driverside window up and down and i can roll my passenger side window down but not up. Does any one know what else would cause this.
Thanks
Adam
Old Apr 25, 2008 | 08:42 AM
4Crawler's Avatar
Thanks
Adam
Probably the switch:
- http://www.4crawler.com/4x4/CheapTri...l#WindowSwitch
Old Apr 25, 2008 | 03:51 PM
ephwang's Avatar
x2. I had the same problem. It was a worn passenger side switch. Search eBay if you don't want to do Roger's trick.
Old Apr 27, 2008 | 07:38 PM
jar73186's Avatar
Alright I will give that a shot with the JB weld as soon as I can get some free time and I'll keep you updated.
Adam
Old Apr 28, 2008 | 09:19 AM
jar73186's Avatar
Ok so I did a little testing over my lunch break. It appears that the rocker is not the only problem. I pulled the switch out and pulled it apart. From what i can see it gets power out of the switch down to the window motor how ever the window only rolls down still no up movement.
Adam
Old Apr 30, 2008 | 06:36 AM
jar73186's Avatar
So I kinda figured it out at least what the problem was. I was having a grounding issue in the driverside door panel. I got that figured out and I can now roll both windows up and down with the driverside now I just have to rework the passenger side again so I can roll that side up.
Adam
Jun 1, 2021 01:51 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
