Installing A New Cam
Im thinking of getting a new cam for my 86 4Runner, i was thinking of the engine builder 261c cam and a downey header. will i see noticable gains with this set up ?, and what about the exhaust, what size pipe should i use 2.25 or 2.50 ?. How hard is it to change a cam, is it just a matter of unbolting the old cam and putting in the new cam and readjusting everything ?.
2.25
not hard. but unless you are truly gifted, you should replace the head gasket. and check the timing chain + guides.
i think that would depend on how high the mileage. i didn't, but then there is only 64k on it when i installed the cam.
I have reused rockers , IF they are in good condition. No abnormal wear, no eaten cam lobes, etc. I break the glaze on them with a very fine emery cloth, then polish with some scotchbrite, by hand usually on glass or a flat surface. I have mic'd the shafts, the rocker bores, etc. The FSM outlines the measurement details.
nonstop
7
Aug 11, 2015 09:26 AM
