3VZE TOP END+homemade ??Y PIPE?? MOD!!!
be carefull with the injectors cause i broke one trying to clean it up ,well it only cost me 112 can dollars for a rebuild one
and i broke a damn bolt inside my head cover right side so be carefull when taking those off!!
yea i know the cyinders looks good thats why im only doing some top end ish. SO heres the problems; hg was blown up left side from front of car,numb 6 valve(intake) was BROKEN??!!! unbeleivable i sended my heads to clean and change numb 6 intake valve and all the other crap i cant do.
I don't think I'd use oven cleaner. That's not going to leave any sort of a lubrication on the surface, so you really need to run assembly lube on the cylinders before throwing everything on and cranking it up again.
What else are you planning? How many miles on your engine? Have you double checked the idler pulleys for wear? I had to replace both mine. I'd SERIOUSLY consider a new oil pump while you've got it apart.
Great pics; you just need to get better at focusing on the thing you're taking a picture of!
