Deck plate mod question
Old May 25, 2003 | 03:42 AM
shovelhead's Avatar
Question Deck plate mod question
I'm new to these boards so HI. Why do you have to pull the EFI fuse do do this mod? I mean if every time you cork and uncork the deckplate don't you run into the same conditions?
Old May 25, 2003 | 06:30 AM
Mikey's Avatar
You know that's a good question about capping and uncapping the deck plate. When i did mine i pulled the EFI fuse and put it back in after about 15 minutes. I didn't have any problems with a check engine light. But if you cap the deckplate, I would think the ECM would have the potential to throw a light on. Anyone else??
Old May 25, 2003 | 06:49 AM
Ric's Avatar
Ric
Banned - User requested
very good question, im waiting on my deckplate to get here, i never thought of that, DO YOU HAVE TO PULL THE FUSE EVERYTIME YOU YOU CORK OR INCORK ?
Ric
Old May 25, 2003 | 08:52 AM
Dr. Zhivago's Avatar
Away
Pffff. No, you do not have to reset the ECU. It adjusts automagically.
I play with WAY more tuning parameters than the deckplate alone will affect and I NEVER reset because there is no need to.
My .02
Dr. Z
Old May 25, 2003 | 10:04 AM
AznSky's Avatar
I guess the reason you have to re-plug the efi fuse is because you disconnected the maf sensor. That's why you don't have to re-connect the efi each time you cap and uncap the deckplate. Because when you install the deckplate you have to disconnect the maf, and that's the only time you'd have to.
Old May 25, 2003 | 10:27 AM
Ric's Avatar
Ric
ohhhh ok,, thankx,, makes sense
Old May 26, 2003 | 04:25 AM
shovelhead's Avatar
thanks DR Z. I suspected as much, as for unplugging the maf as long as the engine isn't running it shouldn't come into play. Do you know if there is any info out there on the intake silencer mod for an'03 taco with the 3.4? the piping seems to be quite different.
Old May 26, 2003 | 09:13 AM
Away
First of all, you're welcome for the info. Secondly, I do not know of any write-ups out there for the '03 3.4L Taco ISR mod. But, if you wanna take some pics and pst them, maybe we can figure something out.
Lemme know!
Dr. Z
colasurdo
Jan 11, 2026 08:10 AM
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TransAmBandit
Jul 28, 2015 11:30 PM
Massmayhem247
Jul 18, 2015 05:46 AM
