Instaling a Tack in my 89 v6
Old Jan 8, 2007 | 09:57 AM
8yota9's Avatar
Hello,
As some of you may notice the 89 or others dont have tacks? well i would like to install one but dont no how eney help i would like to monitor my revs when doing donuts haha
Old Jan 8, 2007 | 10:06 AM
spudrunner's Avatar
https://www.yotatech.com/forums/f115/doing-sr-5-gauge-cluster-swap-how-pictures-51800/
Old Jan 8, 2007 | 01:58 PM
CyMoN's Avatar
are you talking about a sunpro type one you put on the cluster if so the dash ones come with good instructions on how install them
Old Jan 8, 2007 | 05:49 PM
8yota9's Avatar
LIke a little autometer one that sticks on the stering colum. And dose the tack in that cluster install link run off the same wiering harness in my 89 and what year cluster would fit my 89???
Old Jan 10, 2007 | 03:49 PM
8yota9's Avatar
Tack in 89 v6
eney takers pleazz
Old Jan 10, 2007 | 10:27 PM
shoes138's Avatar
all u do is take the negative side of the coil to get the reading! if im reading everyhting rite!
Old Jan 10, 2007 | 11:21 PM
95ToyotaPU007's Avatar
Installing one of these (Part # 52051) in my truck would be sweet.
http://www.secureleadercom.com/fssto...Bit=3&dept=384
Wish I knew if someone made them for Toyota Trucks.
Old Jan 11, 2007 | 06:59 AM
Crymson's Avatar
Jeff Mosk makes 2 and 3 gauge pod pillars for toyota trucks.
http://www.well.com/user/mosk/gaugepillars.htm
Old Jan 11, 2007 | 12:12 PM
Thanks
Old Jan 11, 2007 | 01:08 PM
CanTheWhales's Avatar
This is sorta related.... what's the redline for a 22R? I don't know and if I ever added a tach to my truck I would have to set it. Around 5700 right?
Old Jan 11, 2007 | 03:30 PM
8yota9's Avatar
do i have a coil in my 89 i was told i might not
Old Jan 11, 2007 | 05:00 PM
CyMoN's Avatar
the po installed a mini tach on my truck it was on top of the coloumn but blocked the speedo so I moved it to the side of the steering coloumn.
I have never traced the wires to what they are hooked up to but I know with all gauges they come with good installation instrucktions.
some companys even have their instructions online to look if you loose yours.
google it.
Old Jan 11, 2007 | 05:22 PM
toyota_mdt_tech's Avatar
Originally Posted by 8yota9
Hello,
They did come with tachs, but you either needed an SR5 or the "touring package" which gave you wing windows, tilt, intermittent wipers and the tach dash cluster. I think its almost plug n play, but you will need to change the oil pressure sender, as one was a light, the tach uses the gauge.
Old Jan 14, 2007 | 06:15 AM
8yota9's Avatar
i have a idoit lite fore the oil dos changing it still apply
Old Jan 14, 2007 | 08:27 AM
spudrunner's Avatar
If you do the SR 5 gauge cluster swap you need to change the oil pressure sender
http://autozone.com/servlet/UiBroker...uge&PageSync=1
If your just putting on an aftermarket tach you don't have to change it.
Old Jan 15, 2007 | 08:03 AM
8yota9's Avatar
On my way to the scrap yard today theres a 1989 pu there gonna get me the tack hopefully and a powerstering pump fill tank corner lights and maby some intereor parts ill let you all no how it went
nvdesertrunner
May 11, 2020 08:18 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
