Instaling a Tack in my 89 v6
Hello,
As some of you may notice the 89 or others dont have tacks? well i would like to install one but dont no how eney help i would like to monitor my revs when doing donuts haha |
are you talking about a sunpro type one you put on the cluster if so the dash ones come with good instructions on how install them
LIke a little autometer one that sticks on the stering colum. And dose the tack in that cluster install link run off the same wiering harness in my 89 and what year cluster would fit my 89???
Tack in 89 v6
eney takers pleazz
all u do is take the negative side of the coil to get the reading! if im reading everyhting rite!
Installing one of these (Part # 52051) in my truck would be sweet.
http://www.secureleadercom.com/fssto...Bit=3&dept=384 Wish I knew if someone made them for Toyota Trucks. |
Originally Posted by 95ToyotaPU007
(Post 50390389)
http://www.secureleadercom.com/fssto...Bit=3&dept=384 Wish I knew if someone made them for Toyota Trucks. http://www.well.com/user/mosk/gaugepillars.htm |
Originally Posted by Crymson
(Post 50390549)
Jeff Mosk makes 2 and 3 gauge pod pillars for toyota trucks.
This is sorta related.... what's the redline for a 22R? I don't know and if I ever added a tach to my truck I would have to set it. Around 5700 right?
do i have a coil in my 89 i was told i might not
the po installed a mini tach on my truck it was on top of the coloumn but blocked the speedo so I moved it to the side of the steering coloumn.
I have never traced the wires to what they are hooked up to but I know with all gauges they come with good installation instrucktions. some companys even have their instructions online to look if you loose yours. google it. |
Originally Posted by 8yota9
(Post 50387234)
Hello,
i have a idoit lite fore the oil dos changing it still apply
If you do the SR 5 gauge cluster swap you need to change the oil pressure sender
http://autozone.com/servlet/UiBroker...uge&PageSync=1 If your just putting on an aftermarket tach you don't have to change it.:chair: |
On my way to the scrap yard today theres a 1989 pu there gonna get me the tack hopefully and a powerstering pump fill tank corner lights and maby some intereor parts ill let you all no how it went
