My 84 pickup ground up
Old 04-29-2018, 04:47 PM
NYHumpinUtah's Avatar
Well, I've been on here for a while and been looking and reading and even though I don't really have the time or patience to document my ground up build I thought I'd at least put some pics up I started in Feb this year here's some pics of where I am now
After powder coating and a few days later a rolling frame, completely rebuilt solid axle and rear end
Old 04-29-2018, 05:29 PM
More to come
Old 04-29-2018, 07:10 PM
old87yota's Avatar
It is looking great so far!
Old 04-30-2018, 08:40 AM
jakey poo's Avatar
Nice work! You've caught me in my build now. All this nice weather and the wife wants me in the yard not the garage
Old 04-30-2018, 09:05 AM
What you building? Pics? I've been at it for a while, just now putting it on here. Don't have a ring so I'm good there
Old 04-30-2018, 12:11 PM
SomedayJ's Avatar
More!
Old 04-30-2018, 12:56 PM
jakey poo's Avatar
1983 w/ a 3rz swap its slow going for me lol
https://www.yotatech.com/forums/f197...o-tall-303059/
Old 05-04-2018, 05:25 PM
Got to work on it today, added the brake lines and 1 gas line and the LSPV
Then I put on the tranny mount just to get it out of the way, and mounted the steering box
Skid plates back from powder coating
And the gas tank
And then i installed them
All in all a pretty good day
I have a new gas filter and new hose somewhere..................somewhere.............. .I'll find it when I'm not looking for it
Old 05-05-2018, 12:38 PM
Needed room in the garage so I can start the engine rebuild
getting some nice Utah sun!
Old 05-05-2018, 01:52 PM
old87yota's Avatar
The frame is so shiny and clean!
Is the fuel filler hose new?
Old 05-05-2018, 05:37 PM
No, I just "sandblasted it" Amazing how rubber comes out when you sandblast it. I did the rubber under front fender pieces and they look brand new. I'll take some pics tomorrow. There is also the same rubber skirting underneath the bed, I'll do those as well.
Today I cleaned up a bit and started the engine rebuild. I did the mains and the rods with plastigage and all were within .0015 and .002 clearance, so far so good.Waiting on a dial bore gage to "double check" my machine shop guy who I don't trust anymore.
It's all good, no rush, and I will take my time on the engine.
Old 05-06-2018, 04:34 PM
Quick update
Rotating Assembly is done, crank and pistons in
Spins nice
Old 05-06-2018, 06:23 PM
RAD4Runner's Avatar
Ooooooooh!!!!!
Looking at those pics is almost as good as looking at centerfolds! - LOL!
Wanna see her in person.
Those bolt on the OME clips, Do they clear the fuel tank pinch-weld?
Old 05-06-2018, 08:23 PM
Ooooooooh!!!!!
What clips are you talking about
Old 05-06-2018, 09:56 PM
RAD4Runner's Avatar
The clip that holds the leafs together. Bolt may hit pinch-weld when it flexes.
Attached Thumbnails My 84 pickup ground up-screen-shot-2018-05-06-10.54.36-pm.png
Old 05-06-2018, 10:14 PM
Humm
I'll have to look at that tomorrow, I didn't think I had a problem...................
I know the frame shackle bolt came close but that's not a moving part.
Old 05-07-2018, 10:07 AM
Well, I checked it out today and it does clear, not by much but it is a good 6" from the gas tank. I will however turn the bolt around so the nut is on the outside.
Old 05-07-2018, 06:33 PM
After procrastinating for a few hours I finally put the engine together, oil pump. water pump, timing chain cover, timing chain and head.........sure hope I didn't forget anything............. Oh, and I set the intake and exhaust valves .008 and .012 Put the distributor in and the fuel pump while I was at it
I also put the oil sender(s) in and the coolant drain plug
Tomorrow the intake side.
Old 05-07-2018, 07:00 PM
Melrose 4r's Avatar
Looking good!
I’m excited to see more photos.
Old 05-09-2018, 08:39 AM
Minor setback, still trying to find answers..........
https://www.yotatech.com/forums/f115...stions-304327/
Quick Reply: My 84 pickup ground up
