windows vrtual memery minimum too low
Old Nov 17, 2005 | 06:07 PM
854runner's Avatar
that is what it said. now what is it and how do i fix it? as always thx guys mike
Old Nov 17, 2005 | 11:14 PM
jacksonpt's Avatar
Senior Member
I've done a bunch of reading on it when I've similar problems. I still don't know exactly what it is. The impression I've gotten is that it's like a swap file - it's memory (hard drive space) that windows uses to perform various functions... kind of like a swap file.
I've never found a good way to fix it, and I always end up reformatting. Sorry - hopefully someone else has a better answer for you.
Old Nov 17, 2005 | 11:21 PM
marko3xl3's Avatar
Right click "MY COMPUTER", go to "ADVANCED" tab, hit "SETTINGS" under the "PERFORMANCE" section, go to "ADVANCED" tab, hit "SETTINGS" under the "VIRTUAL MEMORY" section.
Once you are in there, is the radio buttong that says "SYSTEM MANAGED SIZE" checked or no? If not, what is?
My recommendation would be to use "CUSTOM SIZE" and set the minimum to x1.5 of how much ram you have and the maximum to x3 of the amount of ram you have in your system.
Old Nov 18, 2005 | 03:43 AM
jacksonpt's Avatar
Senior Member
Have you tried this with good success? I've heard that it should be 2-3x your ram, also heard that it should be 10-25% of your HD space. I've tried both but never had any luck.
Old Nov 18, 2005 | 04:22 AM
854runner's Avatar
how do i find out how much ram i have? I will give it a try. thx mike
Old Nov 18, 2005 | 04:34 AM
jacksonpt's Avatar
Senior Member
Right click on the "My Computer" icon on your desktop, click "Properties".
In the window that pops up, the "General" tab should be selected. In the lower right-hand corner it should tell you how much ram you have.
Old Nov 18, 2005 | 04:35 AM
854runner's Avatar
Think i found it. 80GB or 256MB. how i know nothing about computers. thx mike
Old Nov 18, 2005 | 05:10 AM
tulsa_97SR5's Avatar
I'm 99.9% sure it's 256, if you have 80gb of ram you are my hero.
Old Nov 18, 2005 | 05:45 AM
854runner's Avatar
2.17 GHz 192 MB of RAM thx guys. what is this mean? thx mike
Old Nov 18, 2005 | 06:09 AM
Churnd's Avatar
You have 192mb RAM, so your virtual memory should be in the neighborhood of 512mb. With such a fast proc, you might want to consider upgrading the RAM. That might take care of your problems, since Windows would have less need to use the virtual memory if it had more real memory to access.
Old Nov 18, 2005 | 07:42 AM
854runner's Avatar
OK i will look into it thx
Old Nov 18, 2005 | 07:45 AM
Localmotion's Avatar
i hear apple is coming out with a powermac G5 that has 10GB or ram...
Old Nov 18, 2005 | 01:31 PM
854runner's Avatar
i have no idea what that means..........
Old Nov 18, 2005 | 02:01 PM
Glenn's Avatar
It just means Apple is coming out with a huge increase in RAM over what most PCs have now. New PCs from the factory have about 512 MB (0.5 GB) to 1024 MB (1.0 GB) of RAM. So what Apple is doing is increasing that at least 10 times.
Old Nov 18, 2005 | 02:05 PM
Churnd's Avatar
I wonder if they'll still be using their old PPC platform, or if they'll be using x86. I can't wait for Tiger to be released for x86.
Old Nov 18, 2005 | 05:28 PM
marko3xl3's Avatar
Works for me. Then again, I have 512MB's so I shouldn't be having a virtual memory problem anyways. Most people say x1.5 for the minimum because the whole virtual memory thing is not efficient and it gets confused when you set the minimum too high.
About Tiger for x86...I think that will only happen if Apple assures themselves a way for no one to use it on non apple hardware which will be VERY hard. If they do it, props to them. If they don't and just use Tiger with x86, they are dumb and will go down!
Old Nov 19, 2005 | 06:16 AM
854runner's Avatar
OK thx guys mike
Old Nov 19, 2005 | 08:44 PM
ldivinag's Avatar
for windows xp, 512 IS THE MINIMUM.
trying to run 256 megs is like asking for too much for the system.
and will end up swapping out to VM.
Old Nov 20, 2005 | 08:59 AM
854runner's Avatar
Ok i have no idea what i am doing. guess its time to take it to a pro. thx
okamikai
Apr 30, 2018 10:19 PM
TDonkey
Jul 26, 2015 10:14 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
RustBucket
Jul 24, 2015 04:46 AM
icentropy
Jul 14, 2015 10:23 AM
