Water Cooling?
Old Dec 26, 2004 | 06:03 AM
jrallan26's Avatar
Water Cooling?
Has anyone tried it? Is it worth it? Whats the hype? Wouldnt adding additional cooling fans be more sufficient?
Old Dec 26, 2004 | 09:05 AM
Del's Avatar
Del
From what I've read about it, it's basically like a radiator for your computer. Much more effecient than fans, but more $$ also. Plus, if you don't do it right, there could be leaks and you could end up with a water cooled heap of metal.
I think water cooling is only really neccesary if you're running a VERY fast system, or plan on overclocking the ˟˟˟˟˟ out of your video card.
Old Dec 27, 2004 | 03:11 PM
CynicX's Avatar
i dont think its really nessasary unless you do have a really souped up PC with alot of overclocking
But its pretty neat for the guru.....
Edit : Oops, I just noticed that Del said that exact same thing I just did....
Old Jan 2, 2005 | 09:32 PM
amusement's Avatar
I haven't used water cooled. I am a believer that water and electroncis don't mix.
If you want more information try tom's hardware:
Tom's hardware articles about water cooling
Old Jan 2, 2005 | 09:58 PM
4Hummer's Avatar
Water-cooling is WICKED for overclocking. I HAD an Intel Celeron 1 gig running overclocked at 2.5 gig and SHE SCREAMED.
WATERCOOLING TIP. Use Mineral Oil instead of Water. If you ever spring a leak you WONT kill anything. You can run an ENTIRE PC (minus the drives) submerged in mineral oil
Might wanna look into Air Cooled to start VAPOCOOL makes some cool stuff (Kinda like a refrigerator for you PC)
Old Jan 2, 2005 | 10:18 PM
jimbo74's Avatar
however oil will not havet the same cooling properties as water... also water and electronics will short out and fry... oil on electronics will short out and catch fire.... something to think about
Old Jan 3, 2005 | 07:37 AM
4Hummer's Avatar
Mineral oil is non conductive
And has great cooling properties. Won't freeze until something like -135. It is very similar to what they use in those big power transformer boxes.
Heres a neat PIC
Old Jan 3, 2005 | 04:29 PM
BruceTS's Avatar
I've tried several different water cooling systems, but neither worked as well as the air cooled systems, my CPU kept overheating.
the1998sr5
27
Nov 17, 2015 09:30 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
ManzDaKlown24
Aug 22, 2015 10:25 PM
mbomberz1
Aug 8, 2015 06:57 AM
TJWilly
Jul 31, 2015 02:05 PM
