Emergancy help Video Cards
So i was trying to upgrade my gforce 4mx to a gforce fx5200. Following the dirrections i removed the old drivers, and now i have nothing. I can see everything untill windows loads and then nothing. HELP
about the only help i can recieve from the pny site is that the onbord driver is somehow on. I dissabled it before installing the hardware, through control pannel. Thier site said i can do it under setup when you boot throught the bios, but i can figure out how. its is a dell motherbord btw/.
If you have an onboard vidcard, you probably need to disable it in the bios. When windows load up, it should automatically load the default drivers for the fx5200.
Then you can go ahead and install the latest nvidia drivers.
u don't do it in windows. the BIOS (basic input output system) is your mothorboad program
every system is a little differnet.
when u turn your computer on hold (f2) on my system. some is shift f2 other f12
you'll then see bios setup page if your board has onboard video disable it. save and turn off the system and restart into windows
Originally Posted by phorunninduke
Thanks, how can i totally dissable this in bios, doing it from windows is not working appearently...
ashamsuddin
17
Jul 22, 2024 03:59 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
