GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Scanners
Old Jan 25, 2011 | 09:55 AM
5vzT100's Avatar
Scanners
Anyone have scanners in their rigs? I have a Uniden Bearcat BC350a that im thinking about putting in my t100. im unsure what to do about an antenna. I really dont want the telescoping antenna floating around in the cab. Post a pic of your setup.
Old Jan 25, 2011 | 10:29 AM
irab88's Avatar
i have one of those, too. nice little radio. i just have it hooked up to my stock antenna. radio shack sells an adapter to use a cb antenna with it. not much to look at, but i want to build a center console and have that on the inside and out of the way.
i'll get pictures up later
Old Jan 26, 2011 | 04:11 AM
5vzT100's Avatar
what is the adapter called? Ive heard that cb antenna only work well on the lower frequencies but will it work well at the 148.000-160.000 range?
Old Jan 26, 2011 | 04:31 AM
meisentones's Avatar
My phone has an app for a scanner. No Antenna needed, but not sure how it compares to an actual scanner.
Old Jan 26, 2011 | 04:35 AM
dropzone's Avatar
Fossilized
if it the one i had on my iphone (5-0 Radio Police App) it kind of sucked..not as many frequencies available on a traditional scanner.
Old Jan 26, 2011 | 05:09 AM
irab88's Avatar
here's a calculator for figuring out how big of an antenna you'll need. there is a formula, but the site does it for you. at 150 mhz, you'll need a 3.12 foot antenna (based on half-wave), which is pretty close to the stock antenna, or a 3 foot whip.
here's the part for hooking up the scanner to a cb-type antenna
here's the part for hooking up the scanner to the stock radio antenna. you'll also need an extension if you're not mounting it directly below the radio
here's my old cb set-up (uses the same type of antenna connector as the scanner). the radio is for sale, by the way
http://www.flickr.com/photos/ianrab/4803253826/
http://www.flickr.com/photos/ianrab/4803253816/
Old Jan 26, 2011 | 06:13 AM
5vzT100's Avatar
thanks for the info. Im planning on using an old magmount cb antenna as the scanner antenna
Old Jan 26, 2011 | 06:39 AM
irab88's Avatar
no problem. let us know how that scanner/antenna combo works out.
jb451
7
Oct 7, 2022 06:58 AM
Tacoma1313
Aug 17, 2015 05:44 PM
cr@ves4wheelin
3.4 Swaps
Aug 17, 2015 07:47 AM
256mbaker
Jul 31, 2015 06:45 PM
Corey
Feb 19, 2006 04:57 AM
