GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Quick question Quick answer re CB
Old Mar 8, 2005 | 03:57 PM
Expat's Avatar
I intend on buying the Cobra 75 WX ST.
Will I gain anything by purchasing a Firestick adjustable end 5ft vs 4ft antenna?
I'm thinking longer means greater transmission/reception distances
Thanks,
Mark
PS does anyone use a 7ft antenna with flag off the roof of their truck? - great for use in dune areas - maybe not so good for tree-lined trails.
Old Mar 8, 2005 | 03:59 PM
epic37311's Avatar
Generally speaking higher the antenna the better off you are. But then things like tree limbs ect. ect. ect. come into play. Best to go as high as you can safley get away with.
Old Mar 8, 2005 | 04:05 PM
epic37311's Avatar
https://www.yotatech.com/forums/show...hlight=antenna
Old Mar 8, 2005 | 04:11 PM
96LtdYota's Avatar
i think its just a heck of a lot easier to tune...
Old Mar 8, 2005 | 04:12 PM
epic37311's Avatar
But alot of people don't have a meter or know how to tune.
Old Mar 8, 2005 | 04:18 PM
jimbo74's Avatar
you can buy the meter for $20 @ radio shack or jcwhitney and it comes with instructions....
if your cb isnt tuned properly, it might lead to failure... i never tuned my old setup and i had a 5 mile range in the city.... but i cant gurantee yours wont blow up...
Old Mar 8, 2005 | 04:19 PM
91Toyota4x4's Avatar
Which is easier to tune?
Old Mar 8, 2005 | 04:20 PM
96LtdYota's Avatar
the firestick II it has the little turn screw in the top, under the red rubber cover
Old Mar 8, 2005 | 04:21 PM
Bob_98SR5's Avatar
serious? if you dont tune...it blows up? never heard of this
bob
Old Mar 8, 2005 | 04:25 PM
Corey's Avatar
Co-Founder/Administrator
The adjustable ones like the Firestik II that I have, and there are some Wilsons out now that have the adjustable tip too that make tuning easy.
Makes it really easy to adjust your SWR.
My Cobra has a built in SWR meter, so it is a snap to get it done.
I am just a hair over 1 on all 40 channels.
Here is an example of a 4' antenna.
You sure you wanna go higher?
Old Mar 8, 2005 | 04:26 PM
epic37311's Avatar
I would imagine it could happen but I don't think anyone not running a modified CB or extra power would EVER have to worry about it. Technically speaking it could happen, with high SWR's but I personally have never had it happen or know anyone who has. I had a pretty big radio and run it forever before I got it tuned. Also it wasn't off very much either.
jimbo74's Avatar
not physically blows up, but i have read in technical bulletins that if your cb isnt tuned and the antenna isn't setup properly that it can do something internally and it wont work at all....
Old Mar 8, 2005 | 04:27 PM
epic37311's Avatar
Doesent the 75 have a SWR meter built into it?
Old Mar 8, 2005 | 04:31 PM
jimbo74's Avatar
good point didnt think of that... some cbs kinda have a swr meter built into them... this cb that i got that hasnt been installd yet has a dyna-mike knob on it, and it says its supposed to help with clarity and power
Old Mar 8, 2005 | 04:42 PM
Expat's Avatar
Thanks for the replies.
Years ago (25+) when I fooled around with cb in cars, we used to make a metal plate to mount the antenna on and then use some U bolts to mount it onto the roof racks (luggage rails).
Does the antenna have to be grounded (bolted in) to the roof to get the benefit of the roof plane or by simply being within the proximity of the roof does this still allow the roof to act as a plane? - No...I am not intending to mount my antenna on the roof but would consider the roof rack if that worked. Otherwise I'll experiment with the traditional fender or rear bumper placement.
Thanks
Mark
Old Mar 8, 2005 | 04:46 PM
epic37311's Avatar
I may be wrong but it would not matter whether or not it was grounded DIRECTLY to the roof. Once it was grounded the whole vehicle would be the plane. I may be wrong just my .02.
Old Mar 8, 2005 | 08:34 PM
Expat's Avatar
I was under the impression that the ground plane was also directional. In other words placing the antenna in the centre of the roof would give the best multi-directional reception as opposed to having it one end which would be more one dimensional.
Any ideas on this?
Thanks
Mark
Old Mar 8, 2005 | 08:40 PM
Expat's Avatar
There seems to be some cross posting so rather than jumping backwards and forwards I will differ to this post...
https://www.yotatech.com/forums/f97/wilson-firestik-ii-53735/
which seems to answer some of my questions I just posted anyway.
Interesting link provided about the relative dB gain comparison between the Firestick and the Wilson.
Old Mar 8, 2005 | 08:52 PM
96LtdYota's Avatar
this should answer most of your basic CB needs... http://www.firestik.com/Tech_Docs.htm
thefishguy77
Aug 9, 2015 04:15 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
4Runnin2000
Jul 29, 2015 06:09 PM
icentropy
Jul 14, 2015 10:23 AM
