Cobra 19 DX IV vs. Midland 1001z
I am looking for a decent CB and not sure which to get. I'd like to go with a smaller model for the fact that it fits in place of the ashtray in the 2nd generation 4Runners.
Which of the two CBs would be the better one?
I haven't seen an install write up for the Midland 1001z. Does that fit right into the ashtray slot after taking out the bracket or does anything have to be cut out?
Thanks for the info.
dont know if you are set on those 2 cb's but here is another option if you dont already have the antenna and swr meter.
http://www.rightchannelradios.com/je...510xl-418.html
At 4.5" wide the 1001z might need a little trim to fit also depending on the model vehicle/options you have space behind may be limited the unit is over 7" long.
The 19dx is about the same width but is almost an inch less deep then the 1001z.
No, I'm not set on anything yet. As I was searching I found a couple people that mounted a Cobra 18 WX ST II, in dash under the stereo head unit. I like that location better than in place of the ashtray.
So the CB you mention, is it a better quality than the other 2 or better because it's a whole kit for about the same amount of money? Or both?
BTW- I had a midland at one time and it was the worst radio I have ever owned
I am doing install on a Midland 1001z now. It is too snug to fit in the ashtray compartment-I am not into cutting up my bezel piece now that I have converted to Limited woodgrain - and besides I want to keep my ashtray. Comes in handy for all that little trash like straw wrappers.
I am exploring installing it in the second DIN position-immediately below the radio itself and it seems height-wise that it will fit. I have a trim plate I can perhaps trim out to cover the blank sections or free up some more space for switches and gadgets.
ahh I see I have jumped an old thread while searching-so if you got one installed you have any photos to share?
ashamsuddin
17
Jul 22, 2024 03:59 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
Sep 3, 2015 09:01 PM
