CB Installation help
Hi, I need to install a cb/pa into my 1990 Chevy Van. I know this is not the chevy forum, but this was the best place (Seems to me) to ask for help on wiring a cb. I have a Cobra 29 that I would like to use. This is my first car, and I know next to nothing about fuses. I hear you can just plug it right into the fuse box? Which slot do I put it in? And secondly, what's the smallest antenna I can use for it? Thanks a bunch
Thanks, but I really just need a clean cut explanation or link or something. One guy used a power box and one didn't. Do I need one? One guy plugged into the windshield wiper fuse, can he still use his windshield wipers...
Read this
http://www.can4x4.com/articles/comcorner/index.htm
all the info you will ever need in regards to CB's
Best to get the power straight from the battery
Use any power supply you want, CB only needs an amp or two of current. Which source to use depends on how/when you want the radio to operate. For example, do you want it to only run when the engine is going, or in the ACC position or all the time? One option is to tap off your AM/FM radio power feed or off the cigaretter lighter. I prefer to run a CB off a dedicated line off the battery (properly fused of course). This way the power is "quieter" and you can have the CB on when the vehicle is off, which I do off-road, when waiting in camp for late comers to arrive.
Check out http://www.firestik.com/ for lots of good CB installation information.
Thanks again guys, I'm gonna go check out those links now. I decided I want to run it through the fuse box definately, just not quite sure how to do it. I want to be able to use it while the cars off too. Thanks
If going from the fuse box, get yourself a volt meter or test light and probe around and see if there are any unused fuse slots that have constant power on them. If so, tap into one of them and go. Depending on the type of fuse, you can often find crimp-on terminals to work with the fuse box. Here is an example of what I did for my Volkswagen:
It is a diesel, so there are boat loads of empty fuse slots. The red and white wires run off to feed something I added on.
Check the back of the CB, the owner's manual or see if there is an on-line installation guide on Cobra's web site. They would have the fuse rating to use, I think many CBs are 1A - 3A or so. on the fuse.
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
